CT Stock size lightend crank pulley
Old Dec 30, 2014 | 01:15 PM
97maximachief's Avatar
I'm gauging interest in a lightweight crank pulley for the 95-01 vq30 engine. This should work for the 3.5 also.
I'm working with a supplier to get them made but might need a few people to show interest in buying it once it's designed. If your interested then message me on here. I can also be reached at 97maximachief@gmail.com
Here's some info I posted on a few Facebook pages.
As most of us know, the only aftermarket pulleys available to us is an underdrive pulley.
Underdrive pulleys are smaller in diameter and don't spin the drive belts as much as the stock one does.
I think Lightweight pulleys are great but would rather not underdrive my alternator or A/C or supercharger in my case.
When you have a aftermarket audio system it's a a big no-no to underdrive the alternator. It will lead to premature failure due to the extra stress of not producing enough juice.
People who run superchargers like my self can not run the underdrive pulley due to the Blower being belt driven. It will see less boost then with the stock pulley.
Reducing the weight with a lightweight flywheel and crank pulley lets the car rev faster and more freely. The stock size pulley will give the weight reduction and still drive the accessories (alternator, a/c, supercharger) with in spec.
Another thing I'd like to mention is the OEM crank pulley is make up of a metal center and metal outer ring. The ring is held on by rubber that tends to dry rot over the years. This will lead to the ring separating from the assembly. Leaving you stranded on the side of the road.
So in conclusion,
The pros are- light weight design, 1 piece design so it won't split into pieces, looks much better then stock, let's you run audio systems with out adding stress to the alternator, can be run with superchargers, keep your same size belts.
Cons- there's none unless you go with a underdrive.
Old Dec 30, 2014 | 09:37 PM
Spoon_'s Avatar
What kind of cost are we looking at?
Old Dec 30, 2014 | 10:12 PM
Fakie J Farkerton's Avatar
You should just start cranking out the trigger rings with screws so people can choose any VQ35 stock size lw pulley they want and bolt the ring on.
Old Dec 31, 2014 | 03:09 AM
IslandMax's Avatar
^Agreed
Old Dec 31, 2014 | 09:55 AM
avin's Avatar
cost?
Old Dec 31, 2014 | 12:36 PM
schmellyfart's Avatar
What supplier?
Old Dec 31, 2014 | 06:26 PM
Fauken's Avatar
Old Jan 5, 2015 | 08:59 PM
Price will be $175 shipped. I'm working with Ralco to get these made.
Old Jan 5, 2015 | 09:00 PM
I want a 1 piece design, no ring needed.
Old Jan 5, 2015 | 09:05 PM
Never even seen one like that.
Would love to see pics.
Old Jan 5, 2015 | 09:18 PM
jwright36's Avatar
So if it is one piece then no "timing " ring needed eh. I see i see interested
Old Jan 6, 2015 | 07:26 AM
A timing ring is still needed. The crank sensor is a hall effect sensor which relies on a magnetic field to determine where the teeth are at on the pulley as it rotates, which means a ferrous metal is required for the timing ring.
Old Jan 6, 2015 | 11:56 AM
^So that's why no one has ever seen it.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
conansriver
Sep 11, 2015 10:26 AM
