Are all 4th Gen ECU's the same?
Old Jul 14, 2002 | 09:36 PM
hakk97se's Avatar
Other than the difference between a 5sp and an Auto, can anyone tell me definitively if all 4th gen ECU's are the same? Is the 95-96 different from the 97-99 at all? What about 99.5's (the ones with some 5th gen style exhaust).
Thanks..
Old Jul 14, 2002 | 10:28 PM
1MAX2NV's Avatar
NOPE!!! There are so many different versions of the ECU for the 4th gen. When I was looking for one, I had to match the number on the ECU sticker. There are several versions just for the 1999. Here's a example. It basically breaks down to.
1. Build date. Before 10/98 or after 10/98.
2. Trim. SE/GLE or GXE. I believe the GXE has a speed limiter.
3. Tranny type. Auto or 5 speed.
4. Tracation control or no traction control.
5. Cali-spec or fed-spec
Old Jul 14, 2002 | 11:15 PM
MaxJag's Avatar
Wow! That's alot of specs
Old Jul 15, 2002 | 12:15 AM
hakk97se's Avatar
Let me clarify. I'm talking physically different. I forgot about the speed limiter issue. I know that the GXE's and most GLE's without C&C have a limiter, and that includes and extra wire. Do the non-limited versions just not have that wire? The other stuff I think is pretty software specific.. Which trim, traction control, cali-spec, etc would seem to be just different software in the same ECU. If there are more physical wires required for the traction control or tranny control, etc then I could see non-software issues. I am simply looking for hardware compatibility. What happens if you try to buy a JWT ECU? Do they need to know every option on your car, etc?
Thanks Again..
Old Jul 15, 2002 | 12:16 AM
hakk97se's Avatar
Also, how much did that ECU cost you and how did you go about finding it?
Old Jul 15, 2002 | 05:07 AM
mzmtg's Avatar
Minister of Silly Walks
GLEs arent limited. And there is no "extra wire" associated with cars that are...
Old Jul 15, 2002 | 06:41 AM
1MAX2NV's Avatar
Physically they are the same. You can plug them in. The problem is when the software would be looking for a signal from a wire but gets no reading. ie. ECU is looking for some form of signal from the traction control sensors, but it couldn't find any.
Thanks Again..
Old Jul 15, 2002 | 06:42 AM
1MAX2NV's Avatar
I got lucky and found it for $100. They usually go for $150 - $300. My car was dead because I shorted out the main processor.
www.car-part.com
Old Jul 15, 2002 | 07:50 PM
hakk97se's Avatar
Appreciate the info guys, I'll try to put it to good use!
MAXSE5SPD
Sep 17, 2022 04:00 AM
QueensMAX
Sep 15, 2015 04:14 AM
Violator
Sep 9, 2015 10:14 AM
mix master
Sep 4, 2015 05:50 PM
