Tire Size Questions
Old Jul 14, 2002 | 10:26 PM
WaarrEagle's Avatar
Tire Size Questions
My 60k mile Michelin MX4 tires and about gone at 23k miles and I am in the market for some new tires. While looking at the original receipt I have a question. It says these tires at 205/65 but everywhere I see says to use 225/50 or 215/55. Are these tires really not meant for my size rim? Also, does it sound rediculous to use up 60k tires in 25k? Now I live in a hilly area and do mostly stop and go driving but my brakes last 30k. Also, my current tires make a kind of whine at speeds above 40. Is that the tire telling me they are low on tread? My front left tire did that and I moved it to the back and it stopped. These tires are on stock 15" rims if that matters. Thanks.
Old Jul 15, 2002 | 07:49 AM
kushane's Avatar
I would stick with either 205/65/15 or 215/60/15. Of these two the 205/65 has the highest profile which means marginally less wheel gap. The 215/65 is slightly wider and and a tad bit lower in profile, but not significant. The 215/60 will give a better footprint than the 205/65 and I would say that's your best bet. Take into accoutn that the rims on that car is a 6.5 inch and anything wider than the 215 may not be a good idea.
What brand of tire are you planning on getting?
Old Jul 15, 2002 | 09:15 AM
WaarrEagle's Avatar
Well, I don't really know yet. I am trying to get some 5 spoke 16" rims first. If I get my new tires prorated I will have to get Michelins. I never hear people getting Michelins for performance. Any suggestions?
Old Jul 15, 2002 | 09:37 AM
kushane's Avatar
Actully, the stock MXV4's held on in my car for 48k and even at the end of their life - I good pretty good dry weather grip with those. I now run Yokohama YK420's (H rated) in the front and this new Kumho tyres (716's) in the rear and they slide around somewhat more than I expected. I like that set up better since it induces a bit of oversteer.
If you are staying with 15's - I would suggest staying with the Michelins if your pro-rate deal works out. If you are still stayting with the 15's but no pro-rate - go with the Yokohama AVS intermediats (on clearence at Tirerack.com).
The MVX4's are a pretty good tire. I've seen them as stock rubber on my cousin's 3.2 TL and also as factory rubber on the Mercedes S500. That should tell you something.
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximaham
Aug 20, 2015 10:23 AM
