97-99 front end...
Old Jul 15, 2002 | 09:54 AM
asianmotorsports2000's Avatar
97-99 front end...
For those of you who don't know... I was in a wreck.. front end damage... body parts and ac condesnser only... anyway... my one simple question... are there ANY fitment problems with using the 97-99 front bumper skin, grill and headlights with the 95 front fenders?
I know the hood is the same but just wasn't sure about the fenders...
Old Jul 15, 2002 | 11:38 AM
mb1's Avatar
mb1
Re: 97-99 front end...
I believe the things you mentioned are all you need. Do a search for front end conversions. I have a 97-99 front bumper for sale in pearl white if you're interested.
Old Jul 15, 2002 | 11:45 AM
Linkage23's Avatar
Everything...
Everything should fit as if it was supposed to. If anything, there might be a slight fitment problem witht he headlights of the 97+ conversion to the 95. Its no problem at all though...you just need to drill a new hole which cannot be seen once done. Good luck.
Are you having a body shop do this or are you?
Old Jul 15, 2002 | 11:46 AM
Uncle Max's Avatar
Yea it'll work I did it on my 96. All I had to do is trim some tin off my bumper frame to make the 97-99 grill fit.
Old Jul 15, 2002 | 11:57 AM
Thanks so far but...
I am doing all the work myself... what do mean the headlights will not fit?... what do I need to get them to fit and do you have instructions?
Old Jul 15, 2002 | 11:58 AM
Re: Re: 97-99 front end...
Where are you, how much and when can I get it?
Old Jul 15, 2002 | 12:28 PM
clee130's Avatar
Most questions are answered in the 4th gen FAQ thread.
Please read the threads in there.
Old Jul 15, 2002 | 12:36 PM
RR95SE's Avatar
Re: Thanks so far but...
If you're using '97 bumper, then of course the'97 head lights will fit. I just did the '97 conversion on my '95 and if I remember correct, the front fenders fit 95-99, but the bumper and hood fit 97-99. All I know is the head lights the body shop put in my car look like projectors. They are real clear, not that cloudy lense my '95 had.
Rhonda
Old Jul 15, 2002 | 01:51 PM
Uncle Max's Avatar
Ok You can swap to 97-99 Headlights withOUT changing the grill and bumper.
But if you do change the bumper you HAVE to change the grill.
The 97-99 bumper will fit 95-99 perfectly.
Old Jul 15, 2002 | 01:52 PM
Uncle Max's Avatar
Oh and NO hood or fender needs to be changed.
Old Jul 15, 2002 | 05:05 PM
Yellowbrother's Avatar
IF U ARE REPLACING THE 95/96 BUMPER COVER WITH 97-99 THEN THE ONLY THING U WILL HAVE TO MODIFY IS THE BRACKETS NEXT TO THE HEADLIGHTS...I PERSONALLY JUST REMOVED THOSE BRACKETS...
Old Jul 15, 2002 | 05:40 PM
black019's Avatar
THANKS FOR THE INFO!
Old Jul 16, 2002 | 03:07 AM
What I am doing is replacing my 95 headlights, front bumper skin and grill with the 97 version... a complete switchout... my original question was "Is there any additional holes to be drilled or bolts on the 97-99 that are not already set up on the 95-96"...
Old Jul 16, 2002 | 06:27 AM
Uncle Max's Avatar
Nope
Old Jul 16, 2002 | 06:56 AM
Kevin's Avatar
Damn you!!! where were you when I needed it a month ago!!!!
Old Jul 16, 2002 | 07:01 AM
Dreizehn's Avatar
Amen.
I never found a hole that didn't fit right.
Old Jul 16, 2002 | 07:27 AM
Kevin's Avatar
I've started the process already and the headlights fit fine without modification. The grill doesn't fit right unlles you have the bumper or cut the grill legs..
Kevin
wyobbagy
Jan 3, 2023 12:03 PM
Hdnseek
Sep 9, 2015 05:55 AM
JoshG
Sep 5, 2015 10:10 PM
jfl330
Sep 4, 2015 01:44 PM
