May I ask a big favor from someone with a '97/'99 Factory Service Manual?
Old Jul 15, 2002 | 11:48 AM
ptatohed's Avatar
Licensed to Spell
Hi. I am thiiiiiis close to buying a HomeLink visor out of a '97 for my '96. I am just slightly concerned that I won't be able to hook it up. I do own the F.S.M. for my car but obviously it's a '96 F.S.M. and they didn't offer the HomeLink in '96. Could I trouble someone to scan and post/e-mail me the page(s) in the '97/'99 F.S.M. that covers the HomeLink? I'd really appreciate it. Thanks so much.
Old Jul 16, 2002 | 09:05 AM
ptatohed's Avatar
Licensed to Spell
:o)
Please. ?
Old Jul 16, 2002 | 09:16 AM
ejj's Avatar
ejj
If you don't get any response by tonight, I'll send you copy when I get home from work. I don't have access to it here at work.
Send me an email at eric@ericj.org to remind me.
Old Jul 16, 2002 | 09:21 AM
ejj's Avatar
ejj
The more I think about it...
I don't think there's any "hooking up" required. I don't know this, but I would bet that it runs off a watch battery or something, and I know that it doesn't interface with the car at all. Its just like any other remote opener.
Old Jul 16, 2002 | 09:29 AM
ptatohed's Avatar
Licensed to Spell
:o)
Thanks ejj, that means a lot to me. I'd really appreciate that. I just sent you an e-mail.
Old Jul 16, 2002 | 09:36 AM
ptatohed's Avatar
Licensed to Spell
:o)
I've thought of that too. But no one can tell me for sure. Is it self-powered/battery-operated? Does it tap into the same power as the lighted mirrors? Is the actual sending unit outside of the visor? Etc, etc. That's why I was hoping for the FSM pages. Thanks again.
Old Jul 16, 2002 | 09:45 AM
ejj's Avatar
ejj
Re: :o)
Understood. I'll dig them up tonight for you. I have a hunch that the FSM won't be a lot of help, as I would think its all self contained in the visor. Hell, if I can't find anything in the FSM I'll take off my visor and look for wires.
Old Jul 16, 2002 | 11:07 AM
Kevin's Avatar
Buddy of mine did it in his Maxaim from an I30 Loaner car. Worked like a charm very plug and play.
Old Jul 16, 2002 | 12:13 PM
ptatohed's Avatar
Licensed to Spell
:o)
Right, but he probably had a '97/'99, right? I figured that would be plug and play. I'm just concerned about it going in a '95/'96. Thanks Kevin.
Old Jul 16, 2002 | 12:45 PM
Kevin's Avatar
Re: :o)
His Maxima is a 96, but I beleive the i30 was a 97.
Kevin
Old Jul 16, 2002 | 01:26 PM
genepool's Avatar
I remember looking at the homelink diagram in my FSM. It appears to be just a regular power supply wired to the visor, nothing special. I don't have a scanner at home but I could try taking a picture of the page with my crappy digital camera.
Old Jul 16, 2002 | 02:18 PM
ptatohed's Avatar
Licensed to Spell
:o)
Any help would be appreciated. Thanks gene.
Old Jul 16, 2002 | 02:30 PM
myiqis180's Avatar
Disconect the battery.
If some one is at home, and has the multi-link transceiver, disconect the batery, and see if it still works. If it does, it has a batery.
Old Jul 16, 2002 | 07:12 PM
ejj's Avatar
ejj
ptatohed - You got mail!
To sum it up, from the way the FSM reads (the quick look that I took), all the Homelink electronics are in the visor, and power is supplied from the fuse box.
Nothing to complicated. The diagram did indicate that there would be a plug somewhere, but your guess is as good as mine.
Old Jul 17, 2002 | 08:16 AM
ptatohed's Avatar
Licensed to Spell
:o)
Eric, I already thanked you via e-mail but, let me do so here as well. I am sooo very grateful to you. You're a life-saver. Thanks again for taking the time to do that for me yesterday evening. Wether it's 'plug and play' is still unknown but I do feel confident that I'll be able to get it working. Thanks again.
Old Sep 5, 2002 | 08:42 PM
ptatohed's Avatar
Licensed to Spell
:o)
Eric, just wanted to give you a follow up 'thank you'. Everything worked out 100% perfect. Thanks again for your time/help.
- Josh
Old Sep 5, 2002 | 09:53 PM
ThurzNite's Avatar
Re: :o)
- Josh
so how'd u wire it?
Jae
Old Sep 6, 2002 | 01:31 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: :o)
Originally posted by ThurzNite
so how'd u wire it?
Jae
It's easier than I ever imagined! It's 100% 'plug n play'. Same number of wires, same colored wires, same plug. My conclusion is if you have a car with lighted vanity mirrors, it will fit right on. I was so stoked!
Now if I only had a garage door...
Old Sep 6, 2002 | 04:22 PM
joaquink's Avatar
¿Hablas Español?
Re: Re: Re: :o)
If you do end up with a garage door to open, be aware of the fact that the 97 HomeLink doesn't work with rolling code doors unless you get a receiver that handles static codes and then transmits a rolling code. Of course, that essentially the security benefit of having rolling codes but I guess it adds convenience. Supposedly late 98 and forward models support rolling codes.
Cheers,
JK
The Wizard
24
Oct 1, 2015 08:47 PM
Pixel
Sep 15, 2015 05:53 AM
