Anyone with interior neons...
Old Jul 15, 2002 | 03:30 PM
Dev's Avatar
Dev
I got a 99 maxima, and im trying to put two neon lights under the dash where peoples feet rest. so i got the passenger side mounted, but i can't find a place to mount the drivers side neon.
for those of you with the same type of installation, where did you put your neons under the driver side dash?? and also, what did you hook it up to? im thinking of the head unit....
Old Jul 15, 2002 | 03:34 PM
BBaker025's Avatar
Post this in the audio/video forum, all those ppl have neons in their car!
Old Jul 15, 2002 | 03:50 PM
Kashoggio's Avatar
just zip tie te neon to anything thats under the dash
Old Jul 15, 2002 | 03:59 PM
steeo's Avatar
Ye i cable tied my neons to the wire loom running under the dash and connected them via a relay to the wire running to the door light so they only come on when the doors open, less hassle from the coppers when i get stopped
Old Jul 15, 2002 | 04:26 PM
clee130's Avatar
I drilled my blacklight into the plastic piece under the dash.
Not recommended.
Old Jul 15, 2002 | 05:46 PM
EN_Maxima's Avatar
I went to Walmart and bough 2 10" neons for 9.99 a piece. They are the kind that plug into the cigarette lighter. I secured the neons to the wire looms under the dash via some zip ties. Then I spliced the wires and ran them through my dash and out my ebrake boot back into 1 cigarette adapter. I'm happy with it, plus hell, it only cost me 20 bucks.
-Ian
Old Jul 15, 2002 | 06:20 PM
Max-Ben's Avatar
-Ian
I keep looking fors this neons at walmart and I'm not able to find them, at all -- totally sucks
Old Jul 15, 2002 | 07:36 PM
96BLUMAX's Avatar
I used to buy tons of the walmart neons. I am pretty sure they don't sell them anymore but I could be wrong. Also the zip tie idea is the best and wire them to a switch and then that through an ignition fuse. Looks much cleaner than pluggin it in to the lighter.
Old Jul 15, 2002 | 09:24 PM
DCmax's Avatar
Screw the driver's side neon under the steering wheel far back on the underside panel.
Old Jul 15, 2002 | 11:20 PM
97BLKMAXSE's Avatar
for the driverside i screwed one end into the plasit and the other end i useded a zip tie and zip tied it to soem wires under there.
as for what to wire it to i wired them to the cigerette liter and to a switch that way i can shut them off
good look
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
carid
Sep 17, 2015 05:00 AM
GregL65
Sep 7, 2015 10:33 PM
