transmission oil check problem
Old Jul 16, 2002 | 06:39 AM
m_spart's Avatar
Hi All!
When I checked my auto transmission oil on cold engine it MUCH above cold mark on probe.
But for HOT mark on working engine it's in proper level.
Is some one else has the same problem?
Greg.
Old Jul 16, 2002 | 07:19 AM
iwannabmw's Avatar
Re: transmission oil check problem
Originally posted by m_spart
Hi All!
Greg.
How did you check it. The most accurate way is to check it after you have been driving for a while. You should leave the car running while you check it also. If you did it that way and it was in the proper range everything is fine.
Old Jul 16, 2002 | 07:22 AM
m_spart's Avatar
Re: Re: transmission oil check problem
I checked it in the morning on cold engine. And I checked it on working engine after 10 min of ride. I'm really confused....
Old Jul 16, 2002 | 07:37 AM
iwannabmw's Avatar
Re: Re: Re: transmission oil check problem
If you checked it after running it for ten minutes and the car was still running when you pulled the dipstick everything is fine. That's is the preferred procedure and how the dipstick is calibrated. ATF expands a lot with heat which is why the level you see are so different. The most accurate is hot with the engine running. If it shows okay then, everything is normal and you have nothing to worry about.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Cotozic
Jun 28, 2017 08:01 PM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxinout93
Aug 20, 2015 02:17 AM
