How do I shut off traction control?!?
Old Jul 17, 2002 | 11:04 AM
Drew96I30's Avatar
Is there a way to disable traction control? Maybe it's just me, but I feel like it really slows down the car a LOT. I got dusted by one of those new Mercedes Hatchbacks yesterday, it feels like my car has like NO pick up off the line. Any help is appreciated!!
Old Jul 17, 2002 | 11:10 AM
I30tMikeD's Avatar
Re: How do I shut off traction control?!?
No, we have no on-off button for our traction control. Do you have an auto? If so that is probably your problem, not traction control. As far As I know it should help launches off the line not slow you down.
Traction control is same as VSLD???? someone clarify that for me please
Old Jul 17, 2002 | 11:14 AM
Drew96I30's Avatar
yeah, it is an auto, and i know that is a big part of my problem. I have driven my old 98SE 5spd, my friends 96 GLE auto, and my 96 I30 auto (with traction control) and my car seems to be quite a bit slower than my friend's maxima. That is why I was wondering.
Old Jul 17, 2002 | 11:19 AM
I30tMikeD's Avatar
The I30 is about 150lbs heavier than a Max, due to extra sound deadening material. I have driven a Max 5-speed and I can't see a difference in my 5-speed.
Old Jul 17, 2002 | 11:20 AM
gryps's Avatar
traction control is a system that decreases engine rpms if it detects a wheel spin
limited slip diff locks wheels together if one spins out
for example
if you spin your right wheel on snow traction control will slow the engine down to stop the spin, vlsd will transfer the power from the spining right wheel to the left without decreasing engines power output
Old Jul 17, 2002 | 11:31 AM
I30tMikeD's Avatar
OK, thanks
I know I have VSLD. Then are we discussing VSLD or traction control? It seems they would not work together well? Can a 5-speed even have traction control?
I don't think I have traction control, just the VSLD.
Old Jul 17, 2002 | 11:48 AM
Drew96I30's Avatar
is there a way to shut off the traction control?
Old Jul 17, 2002 | 12:00 PM
njmaxseltd's Avatar
If you have traction control, which I doubt you do, there is a button on the right next to your dimmer switch that says TCS OFF. When you press it the TCS light on your speedo comes on indicating it's off.
Traction control will not make your car faster. The system only engauges if wheel spin is detected. And belive me when it kicks in YOU FEEL IT. It's just like you let go of the gas pedal when the system kicks on and the SLIP light on the speedo will flash at you.
Does your car have the TCS-OFF switch?
Does your car have the SLIP light on the speedo?
If your answer to any of these questions is no, they you don't have traction control.
To turn off the traction control, just toggle the TCS OFF switch once. The TCS light will light up indicated the system is disabled. It always returns to the enabled state when you restart the car.
Old Jul 17, 2002 | 12:18 PM
Drew96I30's Avatar
Interesting....I just checked and the switch located next to the dimmer is for the gas flap. You are right, I might not have the traction control, but I am thinking that I do, because I have had the car for a month now, and I have not broken traction once. I drive it pretty damn hard too. Hmmmm...
Old Jul 17, 2002 | 12:24 PM
WaarrEagle's Avatar
Well maybe the switch is in a different location in the I30, I don't have a clue. The traction control would really slow you down if you have a small loss of traction off the line becuase it would drastically cut power. So in I30's the place next to the dimmer opens the gas flap? Maximas have that on the floor. Check your owners manual, it should show where the button should be for TCS.
Old Jul 17, 2002 | 12:30 PM
mitch33x's Avatar
Originally posted by I30tMikeD
OK, thanks
5-speed's dont have traction control. Start off in 2nd, thats your traction control
Old Jul 17, 2002 | 12:31 PM
I30tMikeD's Avatar
you may just have a limited slip. I have the Touring model. If Traction control was an option I would have it. And I don't. If I could turn it off and on I would know it. And I can't. I really don't think you have it.
Old Jul 17, 2002 | 12:37 PM
I30tMikeD's Avatar
That's what I figured. Thanks.
Old Jul 17, 2002 | 12:44 PM
Drew96I30's Avatar
REALLY?!?!?! 150lbs of sound deadening material is A LOT of sound deadening. My I30 certianly doesnt sound any quieter than my Maxima.
njmaxseltd's Avatar
I forgot about the electric gas door switch in Infinitis. What are the chances that the TCS system was only offered as an option in Automatic Maxima SE's with the Leather and CC package?
My SE-L has traction control. I've only had it kick in when taking off in snow or on wet roads if I hit the gas to hard. The wheels spin for a brief second, then the whole car throttles down hard, then slowly throttles up again. Works great in bad weather and definately helps you pull out on slippery roads without spinning your wheels to the point you don't go anywhere.
Old Jul 17, 2002 | 12:48 PM
Drew96I30's Avatar
oh well, guess i dont have traction control. i guess the car is just feels like a dog. oh well, i'll get used to it
Old Jul 18, 2002 | 07:50 PM
talisman311's Avatar
I have TCS w/ on/off switch
Correct me if I'm wrong, but I thought TCS was only offered on '99 model vehicles (auto). I have an on/off switch located on the left side of the dash next to the cruise control on/off switch (infiniti). The way I tested it was by doing a hard launch in the rain, you will feel the tcs cut-power like you let off completely on the accelerator.
My 2 cents
Old Jul 18, 2002 | 09:21 PM
infinit30t's Avatar
I still can't figure out if I have the vlsd. I have a 98 i30t auto and haven't a clue if it has it or not, I was told to check the vin # and according to that I have it. Any help you be great.
Old Jul 18, 2002 | 09:38 PM
Drew96I30's Avatar
I was told all I30's have the VLSD?!? Traction control was an option on all (automatic) I30's as far as I know, but it wasn't offered on the Max until 99.
Old Jul 18, 2002 | 09:44 PM
I30tMikeD's Avatar
If your vin # says you have it then you do. I believe that is a reliable way to tell. I can also feel it in a hard turn if I am accelerating through it. I don't know about the auto, but if I pop my clutch and lay a skid both tires will leave markes. Not just one, tire which would mean my VSLD is working. It transfers power to the wheels that grip from the wheels that slip.
It maybe that the auto does not have it, I'm not totally sure. But like you said your vin # says you do.
Maybe you can go and read some old mag articles which explain the different options avalilable? Mayb you could get ahold of Nissan and ask them?
Old Jul 18, 2002 | 09:47 PM
I30tMikeD's Avatar
I would agree that all I30's have VSLD
Old Jul 18, 2002 | 10:10 PM
AkumaMax's Avatar
Does anyone have a pic on a max with the traction control switch.
Old Jul 19, 2002 | 07:19 AM
genepool's Avatar
Check your engine bay. Look at the part right in front of the passenger side and look for the small metal square with printing. It should have your transmission model listed there.
Old Jul 19, 2002 | 10:14 AM
iregula's Avatar
didnt know we had tc
tarun900
19
Dec 20, 2021 06:57 PM
hayne
Oct 5, 2015 11:53 AM
RealityCheck
Oct 2, 2015 06:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
