4th Gen 1995 SE Security
Old Jul 17, 2002 | 04:45 PM
unixsvr4's Avatar
Guys, can any tell me the built in security system from Nissan is it like life time warranty I mean if it's not working properly can you get it fixed. Or if the Panic mode is not operational, does any one has any solution for it, if have my car locked and my windows are down I can manuly unlock the door with my hand but the car does not panic or beep. I need help please. Thanks
Old Jul 17, 2002 | 06:16 PM
pocketrocket's Avatar
Re: 4th Gen 1995 SE Security
unixsvr4
Sorry, but I doubt the system is under a lifetime warranty of any sort.
Panic mode not operational: did you hold the button down for about 2 seconds? One quick tap will not trigger the panic
Manual unlock: Reaching in and unlocking the door will not trigger the alarm BUT opening the door will. If you open the door and the alarm doesn't trigger, try all 4 doors. You might just have a faulty door switch.
One way to test the door switch: turn your dome lamp to on w/ doors (center setting), and open each door individually. Also, your switch might be moody (like mine is) ... try jiggling the door switch (covered by rubber grommet) and if the dome lamp flickers, there's your problem.
Otherwise .. sorry, you're out of luck ... get a new body control module (BCM) OR get an aftermarket alarm that's tons better than the factory's alarm.
Old Jul 18, 2002 | 05:07 AM
Dave Holmes's Avatar
Might be something different than my '97. If windows are down, doors locked, and you reach in and unlock the doors, alarm goes off. Do as pocketrocket suggested. Double check all your connections and fuses, too. Does the alarm work at all? Can you use the remote to lock/unlock/trunk?
Old Jul 18, 2002 | 08:24 AM
Eric L.'s Avatar
It takes 30 seconds for the alarm to arm itself after you lock the car. When testing the alarm, keep this in mind.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
