3 of 4 speeds not working on blower motor
Old Jul 22, 2002 | 05:41 PM
amb4081's Avatar
I've done a search and didn't find a post very close to mine. I was driving home from work with the AC on and the fan speed on 2 (manual AC; no T-stat). All of a sudden, I lost ALL airflow. The AC was still on so I immediately turned the AC off to prevent damage. I tried all 4 speeds and the only one that works is the highest...4. 1,2, and 3 don't work at all. Any ideas? I've been looking through Haynes manual and am going to check the switch which is my first guess.
Also, the Haynes manual says to disconnect the battery to prevent the airbags from accidentally going off while working on the motor. But then it says to apply voltage and check voltage at the blower itself to see if it is the problem. But the manual said nothing about reconnecting the battery. My question is: What are the chances of the airbags accidentally deploying while I'm checking the motor with power on? Thanks in advance. Sorry for the long post.
Aaron
Old Jul 22, 2002 | 05:55 PM
Nismo3112's Avatar
Custom User Title
I had the exact same problem...It is the resistor that sits inside the blower motor. looks something like a credit card. It's a **tch to get to. I had to remove my whole dash passenger airbag just to get to it. The install is easy, there r like 1 or 2 screws that hold it in, swap it out with a good one and ur good to go! hope i helped
Old Jul 22, 2002 | 06:37 PM
pocketrocket's Avatar
I guess it only took me 2 minutes ...
Old Jul 22, 2002 | 06:39 PM
You can push the passenger seat back, and look under. Easy access. No need to remove any trim pieces. Disconnect the connector, 2 screws, replace and reinstall. Less than 5 minutes.
Old Jul 22, 2002 | 07:31 PM
amb4081's Avatar
Where can the resistor be bought? Place like Auto Zone or do I need to go to Nissan?
Also, is it safe to drive the car with the glove compartment taken apart and the motor out? The Haynes manual implies that the airbags can go off with all of that taken apart. Do I need to worry about it? Thank you.
Old Jul 22, 2002 | 07:35 PM
gtr_rider's Avatar
192.168.1.1
Just remove the glove box and your right at the Blower..
Old Jul 22, 2002 | 07:37 PM
Nismo3112's Avatar
Custom User Title
I got mine through a local junkyard..i had to take the whole dash out bcause on my car i had to replace the resistor as well as the 2 servos that open and close the vents. But yeah now that u mentioned it u could probly replace JUST the resistor in a couple of minutes
Old Jul 22, 2002 | 07:49 PM
amb4081
There is no need to take out your glove4 box or airbag or even your battery terminal.
Just make sure your blower is off, push the seat back and look under the dash on the passenger side. You can see the wiring harness go to this rectangular block screwed in to the bottom of the blower motor with two screws.
You can buy one at a dealer, cost about $25 I think. If you need the part number, go to Nissan parts and either search for resistor or browse ... enjoy
BTW, I've heard dealers will charge over $100 to replace it, go but the part and DIY.
Old Jul 23, 2002 | 06:47 AM
amb4081's Avatar
amb4081
Thanks alot. That site helped out alot. It will be replaced today as long as the parts dept. has it in stock. Also, I was moving my hand around under the dash on one of the three screws that holds the blower motor in place and I think I knocked a plug with 4 wires loose from where it was connected. But I don't know what it connects to. It is a blue plug with 2 green wires and two purple wires in it. Any ideas what it's for? I drove my car today with it not connected and so far everything works fine. Thanks
Aaron
Old Jul 24, 2002 | 11:35 AM
amb4081's Avatar
Blower brought back to life!!!!
Hey thanks for your input everyone. It was the blower motor resistor. When I received the new part, I noticed the part number on the actual part is a little different from the original I took out of the car. It looks like Nissan revised the resistor hopefully to prevent this problem in the future. The .org members come through again. Thanks.
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
silver_i35
Aug 3, 2015 11:20 PM
