clock in a 1997 se maxima does not work
Old Jul 23, 2002 | 06:04 PM
derekJ31's Avatar
Why does the clock come on then off and does not keep time any ideas??????
-Derek
Old Jul 23, 2002 | 06:10 PM
Nore474's Avatar
have no clue but mine broke it seems like a lot of maxima clocks brake my friends has a 96 and his is broken also
Old Jul 23, 2002 | 07:37 PM
cbr2's Avatar
well... if you clock does not hold time when the car is off the there is a bad fuse.. check them.. if it a clock failure.. I have one .. first $50 gets it..
Old Jul 24, 2002 | 12:34 AM
derekJ31's Avatar
I have looked for fuse for clock and can not find it any clues would be helpful.
Old Jul 24, 2002 | 01:53 AM
KINGMAX's Avatar
Yeah, all I can think of is a bad fuse or a bad negative terminal connection on your battery( check to make sure it is not too corroded) or possibly a battery on its last leg?
Old Jul 24, 2002 | 02:00 AM
Lonely Driver's Avatar
Re: clock in a 1997 se maxima does not work
Maybe the connector at the back isn't plugged all the way in.
-Derek
Old Jul 24, 2002 | 06:39 AM
MIXXMAX's Avatar
It might be time for a new one. Mine eventually died a few years back. The only way to check is to check the voltage of all the wires going to the clock. If they are good, and your clock STILL doesn't operate, then the clock is dead. This accessory is fairly an expensive one, too! Nissan charges close to $200.00 for a new one. OUCH! You're better off looking for one at a local junkyard. That's what I did....and for only $20.00!
Old Jul 24, 2002 | 07:04 AM
Dreizehn's Avatar
Mine still holds time, but doesn't illuminate consistently. Is this the clock or something else?
Old Jul 24, 2002 | 07:09 AM
JAY25's Avatar
My clock didnt work either out of the nissan dealer and then the service advisor just installed a fuse so that might be your problem or the clock is broken!!
Old Jul 24, 2002 | 09:06 AM
MIXXMAX's Avatar
Most probably the memory is still good in the clock, but the filaments are starting to die/burn out. If you can get your hands on another clock from another Max, try that one and see if that works...if it does, then you know DEFINITELY your clock is bad.
Old Jul 24, 2002 | 10:05 AM
fast97maxse's Avatar
I did the clock mod
(added a switch so I could keep it from dimming when I put the headlights on
- which I always do even when driving during the day)
Anyway, that went fine... for a while.
After about a month or so it started going out every once in a while.
Sometimes just giving the top of the dash a whack would get it to come on again.
When it loses power it resets to 12:00.
Well, I had a hard time removing the dash panel and I could never get it to go back together,
so it was easy for me to look behind it.
If I jiggled the group of wires that the clock wires were in, I could get the clock to come on,
but I could never get it to stay on.
There is a little connecting plug in the back.
I took this apart and put it together. Still no luck.
It is obviously a loose connection in there somewhere (at least for my problem)
and I don't know how to solve it. I can't figure out where the problem really is.
I don't think it is a bad spot somewhere along the wire. And the plug/connector seems fine.
I'd hate to have to replace the little plug - seems like a lot of work.
And I think the clock is fine - it works when it gets power.
I was thinking about using conductive gel in the plug,
but if it leaked around in the plug (likely I think) it would short it out.
Any ideas?
(oh please)
ah2002
Mar 9, 2016 01:42 PM
Samedi
Aug 13, 2015 04:05 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
