what tools should i buy
Old Jul 24, 2002 | 12:56 PM
densetsu's Avatar
I'm going to put on a ypipe and I know what tools I need but can you guys reccomend any good wrench/socket sets that I can get. I will need these tools later so I want something good.(not too too expensive though...) Thanks.
Old Jul 24, 2002 | 12:59 PM
GATORS1's Avatar
For a y-pipe I would recomend a large breaker bar and torch. The bolts on the cat are tough.
Old Jul 24, 2002 | 01:02 PM
densetsu's Avatar
whats a breaker bar?
Old Jul 24, 2002 | 01:10 PM
GATORS1's Avatar
It is a 12" to 24" long bar you can put your 1/2" socket on the end and break the bolt loose with the leverage of the lenghth of the bar. Its very difficult to do it with a ratchet and your likely to destroy the ratchet in the process. The bar is used only to break the bolts loose, then use the ratchet. You should be able to find it at any auto parts store. Also looke for some PB Blaster to soak the bolts with..this stuff is way better than liquid wrench etc..
Old Jul 24, 2002 | 01:14 PM
densetsu's Avatar
on maximadriver.com it says for 95-98 maximas you need a o2 sensor plug, whats that and where do i get it?
Old Jul 24, 2002 | 03:48 PM
WaarrEagle's Avatar
I'm guessing there is some special tool you can use to get the o2 sensors off. I just used an open ended wrench in the correct size and mine came off just fine. I have a 97 too.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
