VI question: Is this MAP/baro switch large enough?
I found a MAP/baro switch on a Mazda MX3 V6. I saw a pic of a MAP/baro switch that someone had posted (ian maybe?) but I could not get a sense of how large or small it was. I was wondering what you guys thought of this one. It is sitting on a piece of regular 8.5x11 printer paper. The nubs where the vacuum lines connect are pretty small, the inside diameter is a little larger than that of a toothpick. What sort of inside diameters are people using who have already installed their VI?
Re: VI question: Is this MAP/baro switch large enough?
I.D.: what are we talking, like two toothpicks?
Let's just say if 1/8" i.d. rubber tubing is too big to hook it up, it is probably too small. Ideally, you want something 3/16" i.d. tubing will be good for or slightly smaller than 3/16th inch. Too small is not good...
Re: Re: VI question: Is this MAP/baro switch large enough?
And that Solenoid looks like it will work great. It doesn't appear to take much pressure for it to work...
It's about the same size as mine.
IanS
HerpDerp1919
Sep 29, 2015 02:02 PM
