EGRC Solenoid Valve troubles...
Old Jul 27, 2002 | 03:11 PM
CFC's Avatar
CFC
Hey guys, I'm getting MIL code 1005 which is pointing to the EGRC Solenoid Valve. My question is what kind of symptoms would I detect with a bad Solenoid Valve? Is it something that would urgently need to be replaced, or can I sit on it till I get a little bit of money? ... and do any of you have a part number for it in the event that I would need to replace it?
Thanks for any advice.
Old Jul 27, 2002 | 06:31 PM
MIXXMAX's Avatar
Re: EGRC Solenoid Valve troubles...
I had replaced this sensor earlier this year. Any code you recieve from the CEL is worth paying attention to. If you don't replace it, you will most probalbly run into other problems as well, because the computer must adjust to the bad sensor. And, in your case, if you leave this sensor unattended, your EGR system will be all screwed up. This sensor is relatively easy to replace. All it is is a small green little "box" with 3 tiny tubes coming out of it (air passages). It can be found at the rear of the front,left cylinder head. I found it easier to remove the air filter assembly. Removing this, you have more room to work with your hands. The tubing was real hard to remove from the old sensor in my car, so I cut the old ones and replaced them with new ones. Actually, the type of tubing does not matter, because only air is passing thru them. Well, once you replace with new one, just reset the computer and you done! The sensor was only $65.00 from a Nissan dealer where I live. I believe the part number was 14956-31U01. Well, I hope this helped any! Good Luck!
Old Jul 27, 2002 | 10:59 PM
max_speed97's Avatar
Re: Re: EGRC Solenoid Valve troubles...
i replaced mine also ealier in the summer....i had to replace both of them from the dealer becasue after just replacing one the cel kept coming on and they replaced the other and it was fine...but i have one question...after u replaced yours when u step on the gas do you hear a whistling sound..this is only when u accelerate at times...because i do...what can it be??
Old Jul 28, 2002 | 04:59 PM
MIXXMAX's Avatar
Re: Re: Re: EGRC Solenoid Valve troubles...
I'm not sure what you're asking. No, I did not hear any whistling of any kind. Is it that maybe you have an air leak somewhere? And what do you mean by replacing "both" of them (sensors). If your talking about the EGR control solenoid, there is only one, I believe, right?
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
homeofbacon
Sep 23, 2015 07:17 PM
tardrex
Sep 11, 2015 07:35 PM
