95GLE Sunroof...No Power
Old Dec 11, 2000 | 06:53 PM
Tampa95GLE's Avatar
I rarely used my sunroof on my 95GLE,but now I can't.When I press the button there is absolutely no sound.I pulled down the panel in the headliner and felt the motor as I pressed the button.Totally dead. I also disconnected the electrical connector and tested the line.There seems to be no power to the motor.I checked the fuse panel, but can't find any fuse marked for the sunroof. I'm sure there must be one somewhere. Can anyone shed some light on this? Thanks for any help provided.
P.S.With little hair left on my head, I probably don't need a sunroof.
Old Dec 11, 2000 | 08:27 PM
Daniel B. Martin's Avatar
This information comes from the '99 Maxima factory service manual. I'm hoping your '95 Maxima is wired the same way.
The sunroof has three(!) circuit protectors.
1) Fuse #12, a 7.5 amp fuse located in the passenger cabin fuse block.
2) A 30 amp fusible link located in the fuse- and link-box adjacent to the battery.
3) A circuit breaker located under the dashboard at the extreme left-hand side. There are two breakers there, and the one with yellow tape is for the sunroof.
Other things to check include the sunroof relay and the two sunroof switches.
Old Dec 30, 2000 | 11:03 PM
Tampa95GLE's Avatar
Thank You Daniel B.Martin......So far it doesn't seem to be either of the first two items you mention. I'll try the third as soon as I have time. I hope that is it. Your imput is GREATLY appreciated.......
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
