300zx Caliper and Rotor Size for Conversion?
Old Jul 29, 2002 | 06:35 PM
Yuri's Avatar
I know that this particular topic has been discussed numerous of times on here, but I could not find the sizes of calipers and rotors that are needed to be used for the conversion. Apparently Nissan produced two different sizes - 26mm and 30mm. Will 30mm work (depending on the wheel size, etc.) or the 26mm setup is the only option? Those with knowlege on this matter please reply.
Thank you,
Yuri
Old Jul 29, 2002 | 09:00 PM
Nealoc187's Avatar
SLOW
26mm and 30mm what? Are you talking about rotor thickness?
Old Jul 29, 2002 | 11:50 PM
Shadow's Avatar
Re: 300zx Caliper and Rotor Size for Conversion?
Don't get the 26mm, they were only used on the early turbos and had a tendency to warp. The 30mm were used on the late 91 and up TT's. Easier to get a hold of, and won't warp as easily. I've got the 30mm ones. The rotor thickness won't affect wheel fitment or anything since the diameter of the rotor is the same. 11", or 10.75" when it's shaved down to fit our cars.
Thank you,
Yuri
Old Jul 30, 2002 | 07:25 AM
KMax2988's Avatar
To tell ya the truth, I have the 26mm on my car and unless ur autocrossing, u don't have to worry about the warping. The good thing about them is that they're a hell of alot lighter then the 30mm cause they're cast aluminum and not iron. My friend had the 26mm's on his Silvia also and he braked like he was autocrossing all the time. They held up to his abuse so it's really ur choice.
Old Jul 30, 2002 | 07:30 AM
KMax2988's Avatar
The cast aluminum is what make them more suseptable to warping because the aluminum can't hold as much heat as the iron. Knowing this, the heat has to go somewhere so it goes into the rotor causing it to warp under EXTREME REPEATED braking. So that's why cast iron 30mm are better for hardcore braking, but like I said before, it's ur choice.
Old Jul 30, 2002 | 08:31 AM
Yuri's Avatar
Re:
Thank you all. You were very helpful.
Yuri
Old Jul 30, 2002 | 09:20 AM
Yuri's Avatar
Re:
Yuri
Old Jul 30, 2002 | 10:17 AM
got rice?'s Avatar
26mm thickness were on early model non turbos only, made 2/89 to 6/90. *All* twin turbos have the 30mm rotor. Non turbos 7/90 and later use the same 30mm piece.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
Socalstillen
Sep 26, 2015 12:01 PM
