Spark plugs
Old Dec 12, 2000 | 06:32 AM
lucky_777's Avatar
I need to do 60K maintenance on 97 GLE and wander what spark plugs should I use. What do you think about BOSH platinum +4 or splitfire?. What is a good place to get NGK plugs at a fair price?
Old Dec 12, 2000 | 07:34 AM
SmoothMax's Avatar
OG
I suggest you go with the NGK platinums. They're expensive as hell, but it's worth every penny. You only have to change em every 60k so if you think about it, they're not all that expensive.
integra.vtec.net/geeser/megamax/60k_service.html
Old Dec 12, 2000 | 10:23 AM
BSwithTF's Avatar
Don't get the Bosch Platinum +4's !!
I had them in my car and I thought they sucked. I raced my girlfriends stock '96 SE and could barely beat her with the Bosch's. Put the NGK's in and I walk all over her. Stay with the NGK's.
Old Dec 12, 2000 | 11:17 AM
Naughty
How much do the NGK Platinums go for???? ......i have 30K on the car right now ..should i be changing my PULGS?
Old Dec 13, 2000 | 10:33 AM
BSwithTF's Avatar
Not till 60k.
NGK's cost me $11/plug at the dealership. I think it's worth it though. Change them 60k and 120k. (At least that's when it's recommended.)
Old Dec 13, 2000 | 11:56 AM
maximumsportZ's Avatar
Lives in a 350Z
help
how do i get to the spark plugs??
i haven't changed mine yet and dont know how to... help.
Old Dec 13, 2000 | 01:13 PM
BSwithTF's Avatar
Re: help
The front 3 are under the plastic cover that says 'NISSAN' on it. The other 3 are on the other side of the engine, closer to the windshield. Once you get the plastic cover off the front, you'll know what to look for. There will be 3 black things, each held on by 2 bolts. Undo the bolts and pull them out and your plugs are down in those holes. Be careful when you remove the rear ones cause its easy to drop the bolts under the manifold. (Been there, done that, it sucks!) It's real easy to do. Good luck.
Old Dec 13, 2000 | 03:36 PM
vbxmaxima's Avatar
I recently posted info on sparkplug changes on my website..
Check it out
http://vbxmaxima.8m.com/sparkplug.html
Old Dec 13, 2000 | 04:20 PM
MaxPerformanceSE's Avatar
Check it out
I went to your page and read about the part where you said the Bosch +4's caused damage to your friend's engine. Can you tell me what kind of damage? I was close to putting them in my car but then I didn't.
Old Dec 13, 2000 | 05:42 PM
Car With No Name's Avatar
What about the new Iridium plugs? Will these outperform the Platinum? I think I'll go with Iridium's when I change mine.
Old Dec 14, 2000 | 10:23 AM
goldmax's Avatar
Re: Re: help
Check your owner's manual...it also has directions on how to replace the spark plugs as described below. How many other manufacturers show you how to do that!!!
Old Dec 14, 2000 | 11:31 AM
buss95max's Avatar
i have denso iridium plugs in mine. i figure if the ngks cost 11-12 bucks..and the densos cost 13-14 bucks..what the hell?..why not spend some extra money and get the good ish.
since i drive my car everyday i couldnt "feel" a difference with those bad boys in. BUT my g/f drove my car before and after, and she made this facial expression and stated that she felt a difference.
Old Feb 1, 2002 | 08:08 PM
maximachad's Avatar
Lifetime Maxer
Does anyone know why the NGK Platinums are so good? I keep hearing that they're the best, but why???
Chad
Old Feb 1, 2002 | 08:28 PM
Victim64's Avatar
Chad
Thats what the ignition system was designed around
Old Feb 2, 2002 | 02:57 AM
iansw's Avatar
NGK Platinums are going for $6.00 each from Extreme Nissan...look in the FS Forums and do a search on "30%"
This deal only lasts until Mardi Gras is over....
I got 12 myself!!!
IanS
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
