Front Alignment only OR All four??
Old Aug 1, 2002 | 08:27 PM
ptrkng's Avatar
i'm about to lower my car this weekend and i was wondering whether i should do just front two alignment or all four alignment??? i searched and there were many different opinions...
thanks
Old Aug 1, 2002 | 08:30 PM
96sleeper's Avatar
Re: Front Alignment only OR All four??
thanks
There is no alignment for the rear of a 4th gen. maxima, only the front can be adjusted.
Vyrus's Avatar
Front only. There's almost nothing (if not nothing) to adjust in the rear.
-Cyrus
Old Aug 2, 2002 | 12:16 AM
97GLE's Avatar
If you have the money, go for a lifetime alignment... every time your alignments off just go get another... pays for itself pretty quickly if you plan on keeping the car long.
Old Aug 2, 2002 | 01:05 AM
black019's Avatar
there is no rear alignment so if anyone tries to charge you for it you better not let them do it!
Old Aug 2, 2002 | 07:09 AM
kushane's Avatar
Like the guys above said, there is no alignment for the rear, but a complete alignment job requires checking the thrust line of the car (i.e. making sure the front and rear wheels are tracking straight as opposed to going sideways if the car had frame damage or something like that). This is why certain places attach sensors to the rear wheels as well when the car is on the alignment jig.
Old Aug 2, 2002 | 09:07 AM
MaxKlinger's Avatar
Hey guys.
This is the first time I've heard that there is no rear alignment on the 4th gen Maxima. Why is this? Because of the solid rear axle? I would think that the camber could still go out, perhaps as the springs get old and lose their tension. I understand, of course, that there are less joints and moving parts in the rear suspension than the front due to the nature of the steering and drive. I am curious to know more.
Old Aug 2, 2002 | 09:24 AM
njmaxseltd's Avatar
Originally posted by MaxKlinger
Hey guys.
Thats right MAxKinger, the solid beam holds everything together nice and tight. There are no adjustments back there. If your toe or camber go out of wack in the rear, something is bent.
You should always have the car aligned using the 4 wheel tracking system. Although you shouldn't pay for a 4 wheel alignment.
This ensures two things:
1) Nothing is wrong in the rear
2) Your steering wheel will be perfectly centered
If you don't have all 4 wheels hooked up to the alignment racks computer, there's a chance, if your car isn't perfectly straight on the rack that your steering wheel will not be centered. Thats why at a good shop, you'll notice that all 4 wheels always have sensors mounted to them. Even on soild axel or rear beam suspension set ups.
Old Aug 2, 2002 | 10:03 AM
ptrkng's Avatar
thanks for your help guys
Old Aug 2, 2002 | 12:56 PM
jayanth's Avatar
our cars can take only front alignment and rear wheels cannot be aligned.Don't let anyone bill you for a 4 wheel alignment
Old Sep 2, 2003 | 09:32 PM
n2oMike's Avatar
Here's some information on adjusting the REAR toe-in on 4th and 5th generation Maximas. Some cars have shims available that bolt between the hub and axle. I guess those aren't available for Maximas. Below is a simple method of bending the axle to adjust the toe.
http://www.nissanperformancemag.com/.../westend.shtml
Good Luck!
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
bbsitum
Sep 11, 2015 04:55 PM
dcam0326
Sep 8, 2015 11:02 PM
