Emissions problem, thoughts?
Old Aug 8, 2002 | 05:33 AM
96BLUMAX's Avatar
I know that everyone or at least a few of you will say, search for this. I'm sorry I don't have time right now so I was wondering if someone can help me out. I just got my car tested today and I passed everything except for: HC ppm and NO ppm at the higher mph. Can someone tell me what this means or what I can do to fix this problem. By the way I passed the low mph but at the higher mph it failed misserably. Whasts the deal with that?
Old Aug 8, 2002 | 06:24 AM
96BLUMAX's Avatar
boing
Old Aug 8, 2002 | 08:10 AM
iwannabmw's Avatar
High HC and Nox can mean the car wasn't warmed up enough, especially with a Y pipe. You need to drive the car at least 30 min before the test. If he tested it multiple times it probably warmed up and your problem is more related to a fuel issue. When was the engine last tuned up? If the sparkplugs are getting old, the fuel may not be burning completely leading to a high HC count. Were they replaced when you put the new engine in? The problem could also be O2 sensor related. If the sensor is starting to get lazy it may not be reacting fast enough to pass the emissions test, but it's still good enough it won't trip a code yet. Those are just a few ideas for you. Good luck.
Old Aug 8, 2002 | 04:27 PM
96BLUMAX's Avatar
My O2 sensor does give a code which says something about increased exaust flow. Also the plugs were not changes after the new engine. I still think that it probably wasn't warmed up enough.
Old Aug 8, 2002 | 04:48 PM
Nismo87SE's Avatar
High HC and NOx is usually from a malfunctioning EGR valve, alot of advanced ignition timing and a bad cat. I recommend you check the EGR valve and see if it functions properly. Next clean it or the EGR tube, on the SR20DE the tube tends to get blocked with carbon.
Old Aug 8, 2002 | 07:41 PM
96BLUMAX's Avatar
I have another question. I recently installed a voltmeter and it says that my car is running at 14volts when on, I guess to due to alternator and 12v(normal) when the engine is off. Is this unusual?
Old Aug 8, 2002 | 08:32 PM
maxedout95's Avatar
Re: Emissions problem, thoughts?
You have a y-pipe or nitrous system ?
Old Aug 8, 2002 | 08:36 PM
nadir_s's Avatar
vicodin ... gift of life
Don't worry, that is the normal. When you're car is turned off, the voltmeter should read it around 12.6V or so and w/ the car running, the alternator is charging it so it will be higher, it can go up to 17V. You're battery and alternator are runnin fine
Old Aug 9, 2002 | 06:24 AM
96BLUMAX's Avatar
Now i know that the autometer afr gauge is inaccurate, but when I turn my lights on i see a drain on voltage on the voltmeter and then my afr guage shows leaner than when i had my lights off. What are you thoughts on this?
Old Aug 11, 2002 | 11:12 AM
96BLUMAX's Avatar
Can I get my last question answered please?
Old Aug 11, 2002 | 02:01 PM
EZEMaxima's Avatar
you have to rewire your afr gauge. It seems like your experiencing a voltage drop when ever you turn lights on. You need to rewire the main 12 volt source of your gauge preferably direct your your battery and/or even double check your ground connection.
Old Aug 13, 2002 | 06:33 PM
96BLUMAX's Avatar
If I wire directly to the battery, the gauge will always be on. How do you get around that?
adamgalazka
Feb 5, 2023 08:24 AM
Hdnseek
Sep 9, 2015 05:55 AM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
