Fixed Idle problem with restting ECU
Old Aug 8, 2002 | 10:11 AM
NmexMAX's Avatar
dot dot dot ...
I had a slight idle problem when my A/C was on.
So I decided to reset my ECU, thinking it may help, and my idle problem was solved. It seems as if you move the screw more or less, the idle will be higher or lower, anyone ever experience that?
Old Aug 8, 2002 | 11:25 AM
njmaxseltd's Avatar
What screw?
Old Aug 8, 2002 | 11:41 AM
goldmax's Avatar
Re: Fixed Idle problem with restting ECU
Resetting the idle and auto transmission using the factory manual procedures (reset ECU, etc.) made a world of difference to the drivability of my car.
NmexMAX's Avatar
dot dot dot ...
Sorry about the vagueness of that omment. The ECU screw in which you use to set/reset the ECU, on ther dash. Not the 'idle set screw' next to the TB....
My bad
Old Aug 24, 2002 | 11:37 AM
Klutch's Avatar
Can someone post the directions on how to do this?
Old Aug 24, 2002 | 06:42 PM
Nealoc187's Avatar
SLOW
1) Stick a screw driver in the screw.
2) Turn.
Yes I've messed with my idle by turning this screw.
Old Aug 24, 2002 | 06:56 PM
meccanoble's Avatar
Sports Button FTW
after installing CAI, i resetted my ecu and put screw all the way to the left. My idle is lower than before and doesn't drive as well....i idle at like .65 to .70 vs before me idling at like .9
Old Aug 24, 2002 | 10:24 PM
jflowers1974's Avatar
Are you saying resetting the ECU fixed the idle, or the movement of the screw? Is it acting like a POT? I find resetting the ECU once a year after a 15k maintance makes a diff. Plus it allows me to then drive her around for a day and then check if I pull any codes.
Old Aug 24, 2002 | 11:16 PM
Speebs's Avatar
I aim to misbehave.
I don't think it's a POT.. I thought it was just a switch that allowed you to enter diagnostic mode and reset the ECU. I don't really see why it should change the idle, except that the ECU would have to re-calibrate the fuel/air mixture after being reset, changing the idle speed? If this is correct, the idle should return to "normal" (how it used to be) after driving the car around for a while.
Old Aug 25, 2002 | 12:07 AM
ny96max's Avatar
im def raising my idle up tommorow, just a lil. IM glad to see you guys are messing with the ECU too, hehe!
Ant
captchaos
Mar 15, 2016 12:18 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
mix master
Sep 4, 2015 05:50 PM
nbstriker10
Sep 4, 2015 04:26 PM
