HELP! Altezza Blown fuses!
Old Aug 8, 2002 | 04:51 PM
96max5sp's Avatar
I need help my altezza lights are blowing fuses. whoever it was that posted before about this same problem how did you solve it?
Old Aug 8, 2002 | 05:31 PM
NickStam's Avatar
http://64.252.156.63/images/usesearch.jpg
http://forums.maxima.org/search.php?...der=descending
Old Aug 9, 2002 | 07:53 AM
96max5sp's Avatar
Ok I tried the search. Last night I found that one of the fillament wires was bent on the inside so I fixed but had to wait to today to get new fuses. I got the new fuses and put them in. The two outside lights worked but not the inside lights. When I took the inside bulbs apart and tapped the light it came on then shortly after blew the fuse again. So then I switched the harnesses and now the inside lights worked but not the outside and when I took it apart and tapped the buld the same thing happened, it came on and then shortly after shorted out. You think it could be the harnesses or what? Please help.
Old Aug 9, 2002 | 08:13 AM
96max5sp's Avatar
I fixed it yay! Anybody else have this problem just change the fuse from a 7.5 to a 10 amp fuse. I was going to do this but didn,t know if it was safe or not so I called custom maxima and this time got through to their tech support and he said it was safe so I did it and it worked!
leatherneck
Sep 30, 2015 09:16 PM
homewrecker
Sep 24, 2015 07:01 PM
conansriver
Sep 16, 2015 12:17 PM
Maxie40
Sep 14, 2015 11:28 AM
