new brakes solved 1 problem...created another
Old Aug 9, 2002 | 09:19 PM
|\|issan|\/|ax's Avatar
If you'll take a look in my "signature" you'll notice I have VGX brake pads. I installed them myself. Here are the problems: 1. A smell emanating from the brake pads smells like burnt marshmellows. 2. The right front brake pad squeaks (didn't before) 3. The brakes "click" when I am braking. Anyone have any solutions to any problems, your help is appreciated.
Old Aug 9, 2002 | 09:33 PM
SLC I30t's Avatar
Re: new brakes solved 1 problem...created another
That burning smell is probably your brakes burning up... this is going to sound dumb, but go back through and make sure that you didn't put the (back side of your rotor that is burning up) pad on backwards. The clicking noise can be a loose bolt that attaches the caliper to the anti torque thingy(looks like a big handle in the front of your brake). It can also because you forgot to re apply your seperating springs on your front brakes. Maybe you didn't put the E brake counter spring on right... Re tighten your lug nuts... I can't think straight, but thats at least a good hour of things to check. Good luck.
Old Aug 10, 2002 | 05:23 AM
njmaxseltd's Avatar
Did you give them time to break in or did you romp on them right after you installed them? If you romped on them, you've burnt them.
Did you reuse the shims? Were the shims in good shape? If not, you should have baught new ones. A squirt of anti squeal between the shim and pad is a good idea as well.
Did you remove the pins the caliper floats on and regrease them correctly?
Did you put the anti rattle hardware back in place?
Did you tighten the bolts to the correct torque?
The brake system on our cars is not that complicated, but everything needs to be in place and in good shape, especially the shims on the back of the pads. If the shims were showing signs of weare, you should replace them. I sprayed Disc Brake Quite which is a glue like anti squeal on the back of the pads before I put the shims on them. This holds everything very tightly together and I have silent brakes.
Old Aug 10, 2002 | 08:54 AM
skeelo34's Avatar
Re: Re: new brakes solved 1 problem...created another
Nissan no longer uses the separating springs. My dealer told me they were of no use.
Old Aug 10, 2002 | 12:09 PM
SLC I30t's Avatar
hmmm, my car has them. maybe on the newer max's
Old Aug 10, 2002 | 12:17 PM
skeelo34's Avatar
Yeah my 96 had them too, but after i lost one, i went to teh dealer to buy one, thats when they told me they dont carry them b/c they serve no purpose. Ive been driving without em since then, and no squeaks or anything.
Old Aug 10, 2002 | 12:26 PM
SLC I30t's Avatar
Thats great. When I lost mine for a day, I could feel my brakes dragging on the rotor. I guess it was just because they were new rotors. Thanks for the info.
Old Aug 23, 2002 | 02:12 AM
munji's Avatar
NAH, I THINK YOUR DEALER IS WRONG......YOU CAN ONLY PURCHASE THE SHIMS IN A BRAKE KIT ~$20
Old Aug 23, 2002 | 04:29 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
who's got that pic of the closeup of the caps lock key on the keyboad?
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
