antenna mast troubles
Old Aug 10, 2002 | 10:23 AM
canoeist11's Avatar
I am trying to replace a power mast and cannot extract the last remaining section of the old mast out of the black plastic housing tube. I have removed the metal nut and the rubber gasket, but the last section seems to be locked in place. Any ideas would be greatly appreciated.
TH
Old Aug 10, 2002 | 10:26 AM
davemax's Avatar
I had the same poblem when i did mine. I kept picking a it with some needle nose pliers until it all came out. Be sure to regrease the grears.
Old Sep 11, 2002 | 10:54 PM
ThurzNite's Avatar
take the whole assembly out, open up the assembly and take out the remaining stuf.
Jae
Old Sep 12, 2002 | 06:58 AM
sinewave's Avatar
According to the '99 FSM.
REMOVAL
1. Remove antenna nut and antenna base.
2. Withdraw antenna rod while raising it by operating antenna motor.
INSTALLATION
1. Lower antenna rod by operating antenna motor.
2. Insert gear section of antenna rope into place with it facing toward antenna motor. (diagram shows it facing rearward).
3. As soon as antenna rope is wound on antenna motor, stop antenna motor. Insert antenna rod lower end into antenna motor pipe.
4. Retract antenna rod completely by operating antenna motor.
5. Install antenna nut (tightening torque: 17.4-34.7 in-lb) and base.
note INCH-POUNDS, NOT ft-lbs.
chisam14
Nov 6, 2018 08:56 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
