Driver side axle replacement question.
Old Aug 12, 2002 | 10:22 AM
BSwithTF's Avatar
I just replaced my driver side axle and there is a lot of play in and out of the tranny. There's no leaks and the car drives fine. I even checked the distance between the tranny and the axle on my car and my wife's '96 and it's about the same. I can grab the axle and slide it in and out about 1/4" (maybe less). The axle slid right in and snapped into place. Is there a problem here or is this okay?
Old Aug 12, 2002 | 10:24 AM
ericdwong's Avatar
If you mean the part where the rubber boot is, that is normal. It HAS to have play in order to deal with the steering, up/down movement of the suspension. However, the part that goes into the transmission should have ZERO play in it.
Old Aug 12, 2002 | 10:50 AM
BSwithTF's Avatar
Uh-oh, I was afraid of that.
It's the shaft that is moving in and out a little bit. Is it not in all the way, or is the another problem? The snap ring snapped into place and you have to use a pry bar to get it out so I thought it was in. Any suggestions?
Old Aug 12, 2002 | 10:52 AM
ericdwong's Avatar
If its not leaking then dont worry about it. I cant remember but I do think in/out motion will have some play. However, up down/side side motion should be zero.
Old Aug 12, 2002 | 10:57 AM
BSwithTF's Avatar
Thanks.
I'll just keep an eye on it. Funny thing about it is, the seal was seeping just a little with the old axle. I couldn't get a seal anywhere in town so I stuck the new axle in with the old seal and now it doesn't leak at all.
fastcarny
May 18, 2020 10:40 AM
lux97Max
Sep 14, 2015 03:54 PM
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
