Drivers side window
Old Aug 9, 2015 | 07:25 AM
fastcarny's Avatar
Drivers side window
I have a 2002 Maxima when i flip the switch without holding it-My drivers side window closes then comes back down a few inches-Never really stays closed 100% would that be a switch problem or is there a trick to fix this? Just wondering.. Thanks
Old Aug 9, 2015 | 09:07 AM
maxiiiboy's Avatar
Yes. You have to reset the limiting switch inside the window. There are several threads on this subject - just search for "window switch".
Old Jun 24, 2016 | 07:57 PM
rnorthern's Avatar
I had a similar issue to the OP. In the process of taking the door panel off to have a look I was disconnecting the white connector for the window/lock controls. The white connector came off in 2 parts and the wires are now loose. I've been looking everywhere to find a wiring diagram that shows which colors go in which pin holes so that I can put it back to how it was to continue fixing the window issues.
Anyone have any idea of where such a diagram might be?
Or, if not, anyone have a picture handy of the pin connectors with the wires in properly?
I have a '02 Maxima SE
Old Jun 24, 2016 | 07:58 PM
rnorthern's Avatar
And, it is the 16 pin (14/15 wires) connector that the wires came loose. Not the smaller one.
Old Jun 25, 2016 | 10:14 AM
DennisMik's Avatar
See your other post in the "I Am New Here" section.
Old May 16, 2020 | 11:21 AM
Phoya's Avatar
Power window switch connector
Does anyone have a pinout or picture of a 2004 Nissan Liberty power
window switch connector? All of the wires fell out of this one as we pulled the door panel off.
Old May 18, 2020 | 10:40 AM
DennisMik's Avatar
The Nissan Liberty is not sold in North America, so we do not have information on your car. A similar vehicle is sold here that is called the Quest. It does not look exactly the same as the Liberty.
I can give you the wire arrangement for the 2004 Quest model, but I do not know if it is the same as for the Liberty. Use this information at your own risk.
2004 Nissan Quest master switch wiring. This view is looking at the connector as it is plugged into the switch.
Code:
  thick green/red (to window motor) ║ 8 ║ 1 ║ white/red stripe (12 volts)
                 green/white stripe ║ 9 ║ 2 ║ empty
                  white/blue stripe ║ 10║ 3 ║ white/black stripe (optional)
thick green/white (to window motor) ║ 11║ 4 ║ green/red stripe (optional)
                yellow/black stripe ║ 12║   ║ ┐
                                    ╠═══╣   ║ ├─ connector keyway
                green/yellow stripe ║ 13║   ║ ┘
                 white/black stripe ║ 14║ 5 ║ green/red stripe
                     black (ground) ║ 15║ 6 ║ blue stripe
                              empty ║ 16║ 7 ║ red stripe
boomerbrian
Oct 31, 2018 10:25 AM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
