Suspention (I SEARCHED, COULDN'T FIND!!
Old Aug 12, 2002 | 11:10 PM
99MaxOnDubsSE's Avatar
Ok, i just finished putting my factory springs on and my springs still pop when i turn the wheel!! i read the post about the rubber thingy at the top between the spring and the plate that bolts to the uhh..... thingy at the top of the wheel well. yeah, that piece was on there... i'm clueless. help. please. i'll do it!! I'LL BUY A HONDA!!! DON'T PUSH ME!!
anyway, please help... i'm tired of all this.
Ben
Old Aug 13, 2002 | 01:20 AM
Nismo's Avatar
Re: Suspention (I SEARCHED, COULDN'T FIND!!
Ben
pop? Im assuming that your strut bearings need to be lubed or replaced.
Old Aug 13, 2002 | 02:49 AM
NightRider's Avatar
Wait for them to settle. It'll go away.
Old Aug 13, 2002 | 05:22 AM
Albertt's Avatar
Give it a couple of weeks >>
When the AGX and H&Rs were installed, there was a slight popping/knocking noise from the front end when steering, but it has since gone away.
Old Aug 13, 2002 | 05:29 AM
njmaxseltd's Avatar
Was the word OUT facing outwards on the upper spring perch?
Old Aug 14, 2002 | 11:10 AM
Re: Re: Suspention (I SEARCHED, COULDN'T FIND!!
i got the strut bearings and put em' on but it still pops. not as bad but it does...
Ben
Old Aug 14, 2002 | 11:35 AM
njmaxseltd's Avatar
Re: Re: Re: Suspention (I SEARCHED, COULDN'T FIND!!
Ben
Something isn't right with the install of the OE springs. They should be silent!
As I mentioned before, make sure the word OUT faces out on the upper spring perch. If it's not correct, your spring will not be seated correctly.
Also the OEM springs have a top and bottom, are yours in upside down?
I believe there are 3 painted dots. They should be positioned like a triangle. The single dot above the 2 dots. If the 2 dots are above the 1 dot, your springs are upside down.
Old Aug 15, 2002 | 09:45 AM
Re: Re: Re: Re: Suspention (I SEARCHED, COULDN'T FIND!!
ok, it turned out to be my strut bearing. i didn't have one on there at all!!! thanks for everyones help tho
Ben
Old Aug 15, 2002 | 10:52 AM
s2cmpugh's Avatar
heheheh i knew it
Old Aug 15, 2002 | 11:56 AM
Originally posted by s2cmpugh
heheheh i knew it
Old Aug 15, 2002 | 01:55 PM
s2cmpugh's Avatar
Old Aug 26, 2002 | 02:13 PM
Ok, the strut bearing stoped the popping for about a week but now the right one pops again!! WTF?!?
Ben
Old Aug 27, 2002 | 11:14 AM
s2cmpugh's Avatar
did u replace both strut bearings or just one?
Old Sep 2, 2002 | 05:02 PM
Just one
Old Sep 2, 2002 | 07:44 PM
RI-Max's Avatar
buy a honda lol j/king
Old Sep 4, 2002 | 04:32 PM
i was actually thinking about a MR2 but i doubt it'll happen...
Ben
Old Sep 4, 2002 | 04:58 PM
Mad Dhan's Avatar
just as a side note here you spell it suspension not suspention. I assume u didnt get search results becasue of it. Glad problem was solved tho
Old Sep 4, 2002 | 08:41 PM
That would solve a lot of problems wouldn't it?? I guess thats why people go to cah-leh-ge
Ben
9aj9
Apr 5, 2020 12:11 AM
doctorpullit
Sep 10, 2015 06:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
crazyespn
Sep 3, 2015 01:30 PM
