How do I change the fog lights?
Aug 13, 2002 | 08:26 AM
I want to change the stock bulbs on my 99 maxima SE to some nice Piaa bulbs. How do I change it? Do I need to get underneath the car and go in from the bottom or can I unsrew something to release the fog lights? Do you have a website witha tutorials on change foglights bulbs and other lighting in the car? Thanks
Aug 13, 2002 | 08:28 AM
Re: How do I change the fog lights?
Quote:
I think you need to remove the whole lamp. Just remove the plastic on the side and take out the screws. Refer to manual for more detail.
Aug 13, 2002 | 08:38 AM
DoGGx23 >>
...Do you have a website witha tutorials on change foglights bulbs and other lighting in the car? Thanks
Here you go chief...
Aug 13, 2002 | 09:19 AM
it might be in the owner's manual. i forget. but they should how to change most bulbs in the car.
Aug 13, 2002 | 12:10 PM
I do not have the manuel and the link does not work. Can you post the whole URL?
Aug 13, 2002 | 07:10 PM
fog light install
the link worked for me. here it is anyway.
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg1.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg2.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg3.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg4.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg5.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg6.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg7.GIF
http://www.seas.ucla.edu/%7Echeston/fogs/fogpg8.GIF
Aug 13, 2002 | 09:01 PM
Just pop off those two little black cover guys that are on the "closer to the center of the car" side of the front of the foglights. Then there's two 10mm bolts that you undo and the light will come out. Then jsut take the cover off the back of the light and put the new bulbs in.
One thing I recommend is to spray some liquid wrench on the bolts and let it sit before you try to remove them. I just broke both bolts on one side and in the process of trying to drill them out dinged my paint and destroyed the ****ing mounts = $40 for a new metal piece.
