New trunk Lid sitting slightly crooked, any ideas?
Old Aug 18, 2002 | 08:32 PM
Kevin's Avatar
just put on my 97+ style trunk and the problem I have now is that it sits slightly higher then on the right side. the lift side aligns properly, but the right side is up a little. Anyone know how I can fix this?
Kevin
Old Aug 18, 2002 | 09:25 PM
NYCe MaXiMa's Avatar
i would go back and re-trace the steps it takes to swap them. Perhaps you didn't tighten something or didn't put something in place on the side that's sticking up.
This is just a stab in the dark though because i have no idea what the process of swapping trunk lids is..
Old Aug 19, 2002 | 01:33 AM
Mad Dhan's Avatar
i got ****ed when this happened to me too. First make sure you aligned the screws on both side so as not to have on side of the side of the trunk father out then the other. If it still lop-sided do this: Life the trunk up(open position) go the the bottom(the pointy part) of the side that is higher. Then place one hand holding the trunk up(hold it right under the inner tail light). Now with the other free hand place it firmly on the pointy end and pull. Do not pull like a sissy, nothing is gonna happen. Do not pull it slowly either you will not move it. All u need to do is yank down(not with all your might, but frimly) like once or twice and it should bend in slightly. If it becomes bent inward too much simply push out until u get the desired height.
btw i srry for the delay on the pm i was in san francisco
Old Aug 19, 2002 | 05:31 AM
Kevin's Avatar
thanks dhan, so basically pull one side of the lid towards the rear of the car in the poiwt position?? I'mm assuming one hand on the lower pointy part and one by the taillight and both are pulling, no twisting right?
Kevin
Old Aug 19, 2002 | 10:54 AM
Mad Dhan's Avatar
Kevin
u got it
Old Aug 19, 2002 | 10:57 AM
Kevin's Avatar
u got it
worked like a charm! thanks man!
Kevin
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
minsbang
Sep 11, 2015 08:48 PM
rbaker100
Sep 6, 2015 02:46 PM
