stock tire size
Old Aug 21, 2002 | 10:30 PM
Parsec's Avatar
stock tire size
I've done a search and all I could come up with are tire sizes for 16-18". I have a '96 SE so I have 215/60/15 stock tires which need to be replaced. Can I go any wider on these stock rims, or should I just stay w/the oem size? Also, only 2 of my tires are going bald, the other 2 are still nearly perfect. Can I get say, 2 pirellis and keep the 2 stock tires, or should I just buy 2 OEM tires.
Old Aug 22, 2002 | 04:25 AM
metallic97gxe's Avatar
Master Will
stay w/the stock size
and you can have two different companies of tires on your car just put the tires w/the most thread on the front...FWD.....
Old Aug 22, 2002 | 04:40 AM
95Max's Avatar
With a 6.5" wide rim you can go with a 225/60/15. Which I have on my car. While you can have different tires on your car it is not recommend since each manufacturer and each tire from a manufacturer has different handling/adhesion characteristics. For example softer tire, one maybe better in dry but not wet....you get the idea.
FYI I have the Dunlop SP5000 on my car. Great tire for the $$$. If money is not an issue, go for Michelin Pilots.
Chris
Old Aug 22, 2002 | 11:40 AM
MiniMax's Avatar
Actually, recent tests have shown that you should put your best (new) tires on the REAR axle . . . regardless of FWD, RWD, or AWD.
The performance tests show doing so will reduce oversteer significantly . . . and oversteer, though parking-lot fun, requires much greater driver skill and concentration, which most have not acquired.
Old Aug 22, 2002 | 11:53 AM
phenryiv1's Avatar
Mod her. Ate her.
I just heard the same thing.
Back to the regular topic, My personal recommendation would be 225/60/15s on the stock rims. Also, did you check out Dunlop SP Sport A2s? That size (ANY 15", really) is pretty cheap at tirerack, and sears/NTB will match it if you add in shippign charges. Then, try to get them to throw in free a install. They almost ALWAYS will if you buy Road hazard. I got them to do it because I reasoned that if I had gone to tirerack, I would not pay sales tax. They will cave eventually...
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
minsbang
Sep 11, 2015 08:48 PM
jfl330
Sep 4, 2015 01:44 PM
