Just weighed my '95 GXE
Old Aug 22, 2002 | 06:49 PM
Supermachoman's Avatar
It weighed in at a lean 2932 lbs. This is with a full interior and ~1/4 tank of gas. I did remove the spare tire as well as the jack prior to weighing it though. Oh, BTW I'm automatic, and as you should know the automatic trasmissions weigh ~62 lbs more than the standards.
Old Aug 22, 2002 | 07:12 PM
Vyrus's Avatar
Under 3000 = Not bad at all considering you've taken no steps to permanent weight reduction.
-Cyrus
Old Aug 22, 2002 | 07:17 PM
-Cyrus
Light weight rims should be here next week. After that.....don't know what's next for weight reduction.
Old Aug 22, 2002 | 07:35 PM
Vyrus's Avatar
Well there's a lot you can do, but almost everything sacrafices comfort. I hope papsmurf doesn't mind my using his cas as an example, but he's got the only Maxima I know under 2700 lbs. This concerns his car:
The Idle Air Control Valve has been removed along with the EGR system. There is no A/C. No compressor, no evaporator, no catch can, no plumbing. The battery is in the trunk. That is the only thing in the trunk. No spare, no jack, no trunk lid supports, no carpet, no anything. There is no rear deck cover on his car as well as no speaker grills. The plastic splash guards under the car and in the wheel well have been completely removed. The flame blanket under the hood is gone. All remnants of the stock airbox have been removed. Including the one under the battery (in its stock location) All sound dampening has been removed. There aren't even any screws in the dashboard! He always rides on lightweight 16s.
Now that's harcore!
-Cyrus
Old Aug 22, 2002 | 08:18 PM
Nealoc187's Avatar
SLOW
My 96 GXE is 2900 with me in it. No spare, jack, passenger seat, 1/4 tank, CF hood, lightweight rims. That's with the 25lb subframe connectors even.
tarun900
19
Dec 20, 2021 06:57 PM
jerrod99_se-l
Sep 25, 2015 03:02 AM
Socalstillen
Sep 20, 2015 11:46 PM
JoelP
Sep 19, 2015 01:08 PM
