hard start
Old Aug 22, 2002 | 10:38 PM
munji's Avatar
hard start
lately it seems that my car hesitates to start, starts nonetheless, but it just seems like it is struggling.........so far i have changed
*alternator belt
*power steering belt
*knock sensor
*fuel filter
*regular oil changes
-the odd thing is that i just changed to quaker state synthetic blend oil when it began to happen, yet i have used no oil........
Old Aug 23, 2002 | 06:34 AM
StygianMax's Avatar
You & me alike. I've just startedaving probs cranking my engine also. I noticed our Max's are the same yr! Hmmm...
Old Aug 23, 2002 | 06:43 AM
njmaxseltd's Avatar
How many miles are on the plugs?
Ever clean the throttle body out?
Run a bottle of Techron Fuel system cleaner through.
Old Aug 23, 2002 | 07:05 AM
Bo Hill's Avatar
What's the mileage? Try changing the plugs(gapped properly) and maybe the wires. How's your idle when the car is running? Both hot and cold.
Old Aug 23, 2002 | 10:07 AM
cmac95gxe's Avatar
Maximaniac
alarm problem
It could be the factory alarm. I had the same problem. I got an aftermarket alarm and it fixed my starting problem. You might want to have your alarm checked out. I also have automatic start now by the way.
Old Aug 23, 2002 | 10:36 AM
munji's Avatar
sorry i forgot to say, i also have changed my plugs, Denso's and i have a Clifford Matrix RS2.........i'll try the techron, and clean my throttle body
Old Aug 23, 2002 | 11:15 AM
StygianMax's Avatar
Originally posted by munji
sorry i forgot to, i also have changed my plugs, Denso's and i have a Clifford Matrix RS2.........i'll try the techron, and clean my throttle body
I feel like a tag-along in this thread.....but yep, I just had my plugs changed within 2 months AND I cleaned my throttle-body. I'm still
Old Aug 23, 2002 | 04:06 PM
cmac95gxe's Avatar
Maximaniac
alarm?
Old Aug 23, 2002 | 04:41 PM
munji's Avatar
yeah, that is strange.........my car easily starts remotely, but difficult manually.........
Old Aug 23, 2002 | 05:21 PM
nadir_s's Avatar
vicodin ... gift of life
Re: alarm problem
Want to know why your aftermarket alarm fixed it? WIRES!!!!!!!!!!!!
Check your wires that are connected to the starter. They may be corroded and can't provide proper conduction. A good test is to disconnect the starter wire (+) and connect a seperate wire to it and then touch the other end to the battery (+) terminal. Make sure your keys is in and switched to the ON/ACC position. If the car starts normally, then you have a problem w/ the wiring.
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
