Very difficult to change out of Park
Old Aug 25, 2002 | 01:51 AM
|\|issan|\/|ax's Avatar
As the subject reads, it's impossible to change out of park just using the button on the shifter.
I believe I spilled Coke down underneath all that plastic and f*cked it up. There is a little tiny motor (I think) that helps take the car out of park, but it's not engaging. So for now, I am using a screw driver to manipulate it, but it's retarded!
Do I need to replace the electrical motor that helps change out of park or just clean it?
Thx for your help!
Old Aug 25, 2002 | 09:08 AM
Charcoal95GXE's Avatar
might just be me
but um my 95 has a shift lock to where you have to push in the brak as well as push in the button
Old Aug 25, 2002 | 08:44 PM
Re: might just be me
Yes, I am pushing in the brake! I am not that ignorant. Anyway...does anyone know what the heck is going on??
Old Aug 25, 2002 | 08:46 PM
96BLUMAX's Avatar
Mine started doin that a while ago and I just pushed it in and out a few times to loosen it up and after a while it is better. Its probably just getting old.
Old Aug 25, 2002 | 08:48 PM
Tdrice80's Avatar
Re: Re: might just be me
when i park my car on an incline it is hard to shift out of park. maybe thats your problem. do you park on an incline?
Old Aug 25, 2002 | 08:53 PM
AsthmaMax11's Avatar
Re: Very difficult to change out of Park
Thx for your help!
I have the same problem, but not as severe though. I wish there was a way to clean out the whole trans. I agree that the problem is caused by fluids leaking though the shifter.
It doesn't matter if I am at an incline or not. My question is, is it a "do it yourself" or take it to a mechanic??
Old Aug 25, 2002 | 09:09 PM
Stillen_I30's Avatar
i have the same problem...when I park my car in the driveway (inclined) its difficult to shift out of park, and I must pull teh shifter back really hard. Anyhow, a friend had an older accord ('92) and she had the same problem...until one day, it was virtually impossible to shift the damn thing out of park. Their mechanic changed the wire that leads to the shifter and the problem went away.
Old Aug 25, 2002 | 09:15 PM
WaarrEagle's Avatar
You know you can use the e-brake to take the pressure off the transmission on an incline and this problem will go away. At least thats how it works on every car I have ever parked. Maybe you have a different problem though.
Old Aug 25, 2002 | 09:20 PM
96BLUMAX's Avatar
mine used to be bad even with the e-brake.
Old Aug 25, 2002 | 09:25 PM
yeah i had forgotten to mention that i ritually use the e-brake every time i park. it has been difficult to shift after I leave the car sitting for two days. I presume it will get worse over time unless I figure out how to fix it.
Old Aug 27, 2002 | 09:33 PM
Okay, coke was the problem, and WD-40 is the answer. Give the thing a few squirts and it should be just as good as new.
Old Aug 28, 2002 | 12:35 AM
chris j vurnis's Avatar
Exactly how and when do you set the e-brake.
When I park on an incline, I press the brake pedal, then pull the e-brake, shift into park, and then release the brake pedal.
When I go back out of park, I press the brake pedal, shift to reverse, then release the e-brake, then release the brake pedal --
When I do it all in that sequence, I got no problems.
Old Aug 28, 2002 | 08:54 AM
NYCe MaXiMa's Avatar
on my 98 auto
my driveway is inclined and it is hard as hell to shift out of park..
so I started the e-brake thing
pull the e-brake before you go into P
Old Aug 28, 2002 | 09:22 AM
Albertt's Avatar
Will you guys... >>
...quit it with all that "incline" talk already?1?
You're going to give that poor kid |\|issan|\/|ax a heart attack.
Old Aug 28, 2002 | 09:41 AM
NightRider's Avatar
BTW the reason for the shifter getting stuck is because there is air trapped in the shifter lines. It needs to be bled just like your brakes. Hope this helps.
Old Aug 31, 2002 | 08:05 PM
"Heart Attack"
Hahahaha I won't have a heart attack. I will just let them complain about the incline. Doesn't matter what kind of car you have, it's always going to be difficult to change into gear, on an incline. Think about it, all the weight is putting pressure on the car...
spazma7ik
Jan 12, 2017 09:38 PM
Sir Tilus
Mar 22, 2016 01:49 PM
05RLS2
Sep 27, 2015 09:24 PM
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
