Use Premium gas for maximum performence::: true or false?
Old Aug 27, 2002 | 06:31 PM
Sexima's Avatar
does it really make a difference between 89 94 gas?
except the fact that it's good for the engine
Old Aug 27, 2002 | 06:37 PM
LeonBlackMax's Avatar
True
Old Aug 27, 2002 | 06:53 PM
Shaggy
true, but where do you live that you can get 94. around here (knoxville TN) the choices are 87 89 92 and 112 race fuel which melts a cat. lucky
Old Aug 27, 2002 | 07:05 PM
Sexima's Avatar
whoa.. i dont get race fuels here
Old Aug 27, 2002 | 07:06 PM
iwannabmw's Avatar
True, in the VQ's case, the ECU is programmed to take advantage of the higher octane fuel's resistance to detonation. It allows the use of advanced timing with a relatively high compression ratio to squeeze more power out of the engine. 87 octane can be used, as the engine has a knock sensor that retards the timing to prevent any damage, but this is at the expense of power. Depending on your driving style, this can also effect your fuel ecomomy.
Old Aug 27, 2002 | 07:09 PM
Sexima's Avatar
so I'll get better 1/4 time?
Old Aug 27, 2002 | 07:11 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I see a huge benefit performance-wise from premium gas so to answer your ?, Sexima, it would be true
Old Aug 27, 2002 | 07:13 PM
Vyrus's Avatar
END THE THREAD RIGHT HERE! Unless you don't believe Nissan...
-Cyrus
Old Aug 27, 2002 | 07:14 PM
venompwr2's Avatar
racing fuel will do that!?! They sell it out here and I was going to use it once to see if there would be any performance diff, but if its going to screw up my cats, then never mind.
Old Aug 27, 2002 | 07:15 PM
VQdriver's Avatar
to me, as long as it's premium the car runs faster. my best time is run from cheap citgo 93 octane. my previous best was from expensive sunoco ultra 94. i've also run a couple disappointing passes on the expensive stuff. outside factors count a lot more than fuel, provided it doesn't clog your fuel pump/injectors. i've had that happen before. no fun at all.
Old Aug 27, 2002 | 08:27 PM
maximised's Avatar
Re: Use Premium gas for maximum performence::: true or false?
I've always noticed a difference in around-town driving when running premium gas. Its better, cleaner, and really does contribute to getting the most out of your car. I have uncles who get 300 and 400k miles out of their cars with no problems, and they will tell you the reason why: "Change the oil every 3k, and always use premium gas".
Old Aug 27, 2002 | 08:59 PM
BEJAY1's Avatar
Conecarver
I'll call my autoclub to tow me before I put anything but premium in my baby.
Old Aug 27, 2002 | 09:09 PM
meccanoble's Avatar
Sports Button FTW
TRUE, i feel a big difference in performance between plus and premium and i think 92 and more is recommended for MAXIMUM performance (just look on the gasoline lid). But i go to the cheap spots that sell like low 90's (highest i ever seen was 93) but the cheap gas seems to last a lot less than the expensive one...u think they purposely make it more liquidy or something?
gavin68
Sep 18, 2021 12:36 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
