painting engine
Old Aug 28, 2002 | 01:30 PM
pjalst
painting engine
Can you use Caliper paint on your engine to paint the valve cover? I'm only asking because I have some left over.
Old Aug 28, 2002 | 02:53 PM
syc's Avatar
syc
Re: painting engine
yes. my friend did it to his car. but I'm not 100% sure all caliper paint are OK.
Old Aug 28, 2002 | 03:11 PM
16ftpole's Avatar
Re: painting engine
How much left over? I painted my valve cover (bought engine enamel for like $3) and almost used all of it. So be careful, you will probably need more than you think, at least to make it look good. I say just go to autozone and buy some for $3 or $4.
Old Jan 12, 2003 | 05:01 PM
JeffCatt's Avatar
Re: Re: painting engine
Would this be like a weekend type "mod"? Does the paint have to like cure for a while?
Old Jan 12, 2003 | 05:24 PM
95CustomMaxima's Avatar
It only takes about 5 hours to do this...what i did was paint my valve cover and then an hour later put another coat on and it came out perfect....i decided to let it dry for 4 hours just to be safe..Looks absolutely perfect...easy, cheap way to clean up your engine
-Nick
Old Jan 12, 2003 | 06:19 PM
Ramius83
Well, if you use Caliper paint, that crap dries quickly. You can easily do 4-5 coats in less than an hour. But I do recommend that you sand the valve cover a little bit. This will make the job look more professional...
Old Jan 12, 2003 | 06:27 PM
Sin's Avatar
Sin
Re: Re: Re: painting engine
Hey, you have a very similar combo. I used to drive a Volvo 850 Turbo (now my dad's car), and I now drive a 5spd SE 4th gen (98').
Old Jan 12, 2003 | 07:20 PM
nine7se's Avatar
-Nick
What type of paint did you use?
Old Jan 12, 2003 | 07:55 PM
madmax97's Avatar
Hmm
Few question people, i gave this idea a whirl and no luck. I bough a can of spray from autozone for like 3$ and went home and tried to spray it, but the paint wouldnt stick it just ran right off. Do i need to clean or prep it with something first. Or maybe a different paint. My cover is a hard plastic material, is that what everyone elses is? Any ideas or info on my problems are greatly appreciated thanks
Old Jan 12, 2003 | 08:09 PM
I used engine enamel paint from autozone for $3...I also took my valve cover and soaked it in soapy water and scrubbed it clean before i painted it.
Hope this helps,
-Nick
Old Jan 12, 2003 | 09:07 PM
bizz's Avatar
listen from experence, do it on a day where you go nothing to do!!!
make sure you have new gauskets if your taking it off!.. get primer.. and get paint that can hold up to 500+ degree's other wise it will melt and drip everywhere.. anyway take it off.. degreese it.. prime it... let it dry for a hour or more.. and now paint it with very thing coats.. i did 1 big coat and messed mine up! give it like 10 THING coats of paint.. and hold the spray paint at least 10 inchs from the valave cover!... good luck! ps make sure the paint is go metal!
Old Jan 12, 2003 | 09:41 PM
nine7se's Avatar
Hope this helps,
-Nick
Thanks for the info.
This paint is spray on, correct?!?
Old Jan 12, 2003 | 09:48 PM
DanSE's Avatar
I was thinking of doing this as well. For those who have done this, did you spray the whole thing or just the letters or everything but the letters? Did you use tape to block the non-painted surface?
Thanks,
Dan
Old Jan 13, 2003 | 07:04 AM
Yes the paint is spray paint.
-Nick
Old Jan 13, 2003 | 07:23 AM
1MAX2NV's Avatar
Seems like half of the people are talking about spark plug cover and the other half is actually talking about the aluminum valve cover. Spray paint on anything won't last long. If you want something that reallly sticks. Powdercoating is the way to go.
Old Jan 13, 2003 | 11:44 AM
MacGyver265's Avatar
Can't powder coat Plastic (Spark Plug Cover)!
Old Jan 13, 2003 | 01:31 PM
16ftpole's Avatar
Most people i have seen paint their spark plug cover. Here are some pics of my valve cover painted (not spark plug cover).
http://www.people.fas.harvard.edu/~przekop/pics.html
rich
Old Jan 13, 2003 | 02:42 PM
rich
16ftpole: what temperature paint did you use to paint the valve cover?
-Nick
Old Jan 13, 2003 | 03:34 PM
maximaah's Avatar
rich
LOL! Love the shot of your resonator.
Old Jan 13, 2003 | 04:59 PM
JeffCatt's Avatar
Well
I picked up a can of "Plasti-kote" Brake Caliper Paint today.
It was $4.99 at Advanced auto Parts.
The label reads 900 degree coating, with Chemical, chip, and rust resistant.
On the label it also reads that it's made for Brake calipers, brake drums, engine blocks and components.
I apparently can't apply it yet, though, you can only spray it when the temp out side is between 60F and 80F to ensure it cures properly. It takes about 3 to 4 coats but to be safe I'll use 5 if I have enougth.
Old Jan 13, 2003 | 05:26 PM
1MAX2NV's Avatar
http://photos.imageevent.com/1max2nv...e/DCP01149.JPG
http://photos.imageevent.com/1max2nv...e/DCP01147.JPG
Old Jan 13, 2003 | 05:58 PM
DanSE's Avatar
DUDE! That looks SOOOOOO good. Where did you get that done? Is it powder coated or spray paint? How much did it cost? Is it a pain to get off?
Thanks,
Dan
Old Jan 13, 2003 | 07:31 PM
maximaah's Avatar
Old Jan 13, 2003 | 07:45 PM
Rufus's Avatar
why would i need new gauskets when i take the valve cover off?
Old Jan 13, 2003 | 07:50 PM
pjalst
Old Jan 15, 2003 | 08:27 AM
16ftpole's Avatar
-Nick
Nick,
I j/ went to autozone and found red engine enamel. I forgot what it was rated at for temp wise tho (don't have the can anymore). I remember though it was ford red for the color, and it just said engine enamel, and i checked that it was rated high enough. no problems at all. it was only like $3, but i used almost the whole can. hope that helps
rich
Old Jan 15, 2003 | 09:39 AM
1MAX2NV's Avatar
Polished and then powedercoated with candy blue color. R&R valve cover is like a 20 mins job. Cost...about $180 includes new spark plug gaskets.
Thanks,
Dan
Old Jan 15, 2003 | 05:52 PM
DanSE's Avatar
R&R ???
shilov
Feb 19, 2024 09:40 PM
seesole
Sep 14, 2015 12:38 PM
16_SR
Sep 9, 2015 07:14 PM
Hdnseek
Sep 9, 2015 05:55 AM
