What type a spark plugs should i use?
Old Aug 28, 2002 | 09:57 PM
mikey62681's Avatar
I would like to replace my spark plugs this weekend, i would like all your suggestions on what the BEST spark plugs that you recomend, and price. Also are they easy to replace and is there a site to go to for this info, let me know.
Thanks,
Mike
Old Aug 28, 2002 | 10:46 PM
maximised's Avatar
Re: What type a spark plugs should i use?
NGK makes great spark plugs, get their platinum series. It is probably a waste of money if you buy other types, i.e. Splitfire, etc.
I work at a Ducati/Aprilia Motorcycle dealership and we have dyno'd different bikes and setups, the best power is made by using NGK plugs and Exxon Premium gas. Ammoco Ultimate sucks, it makes for some nasty buildup
Old Aug 28, 2002 | 10:50 PM
Requin6's Avatar
Thanks,
Mike
NGK Platinums...the same ones that came in your car from the factory.
www.courtesyparts.com sells them for about the cheapest i have seen.
http://vbxmaxima.8m.com/sparkplug.html on the install. and yes they are pretty to replace if you are handy. the one in the back right needs to have a bracket removed, but its not a big deal (just remove one nut)
Old Aug 29, 2002 | 12:33 AM
sbslacker's Avatar
Also get a price from here... http://www.ngkwholesale.com/
Old Aug 29, 2002 | 03:48 AM
$tillen$ux's Avatar
Densos or NGK's ONLY! NO BOSCH! Although bosch's are standard equipment in benzes etc., they are not liked by your max! Stick to japanese. NGK are preferred and worth the expense!
Old Aug 29, 2002 | 07:24 AM
blackhawk's Avatar
This is a bit off subject, but how do you know if it's really time to change your spark plugs? What are the signs? Is it necessary to change them around 60k miles? I have about 65k miles on my car and haven't change them yet, but I haven't notice a difference in my car's performance. Sorry for going off subject a bit, thanks.
Old Aug 29, 2002 | 07:42 AM
Requin6's Avatar
i would change them whenever you get the time. you may not feel the loss in performance because its a very gradual loss. i didnt think i needed to change mine either but i did just to stay on maintenence, and it restored the power back and ran a lot smoother. not to mention i got 1-2 mpg back!
Old Aug 29, 2002 | 08:59 AM
MONTE 01&97 SE's Avatar
Replace them with the Stock NGK plat's.
Old Aug 29, 2002 | 07:10 PM
keener's Avatar
I second Requin6's comments...changed mine along with air filter and saw a 3mpg increase on my last trip out west.
Old Aug 29, 2002 | 07:13 PM
ny96max's Avatar
NGK Platinum's
Ant
Old Aug 29, 2002 | 10:46 PM
JsL's Avatar
JsL
You should get the stock NGK Laser Platnums. Check out www.monarchproductsinc.com
Old Aug 29, 2002 | 11:57 PM
zntema's Avatar
Ngk also offers the iridium plug is a good plug for replacement for the stock platinums ? will it give any better performance or mpg?
thanks!
Old Sep 3, 2002 | 01:30 PM
fst96se's Avatar
Definately do the NGK's, Mike. Your dealer hookup can definately get them cheaper. The dealer carries the NGK Plats because they are OEM for our cars. Hollar at me and we can put them in!
Old Sep 3, 2002 | 01:58 PM
goldmax's Avatar
Re: Re: What type a spark plugs should i use?
And the best gas is???..........Need INPUT!!! Tx.
Old Sep 3, 2002 | 02:37 PM
maximised's Avatar
Re: Re: Re: What type a spark plugs should i use?
Seriously, Exxon Premium makes the most HP, burns well also...Ammoco Ultimate was good when it first came out, but they have taken all of the good stuff out of it, plus it can gum up everything.
Get Exxon/Mobil!
Old Sep 3, 2002 | 02:39 PM
maximised's Avatar
Re: Re: Re: Re: What type a spark plugs should i use?
It seems that I remember getting good results out of Texaco too, maybe thats why they seem to charge more for their gas
Old Sep 3, 2002 | 04:49 PM
HondaKiller718's Avatar
Best sparkplug advice:
STICK WITH STOCK
Old Sep 3, 2002 | 05:11 PM
silvermax2k2's Avatar
should get NGK Platinum's, but i put in the bosch platinum ones, and they seem fine... whatever you do, do not get the platinum +4's.
Old Sep 3, 2002 | 08:18 PM
MaximaMoJo's Avatar
I heard gas additives change from state to state. The base octane and formula stay the same just additives for smog and enviromental factors can be different, from state to state. So say NY gasoline won't be the same exact formula as IN gasoline. This is what I have heard. So logically these additives could lessen or add to deposits in our Maximas?
Old Sep 21, 2002 | 08:41 AM
Blade_99SE's Avatar
Your right and the the stupidest thing I ever heard of. Did you know in 1994 or 1996 there were only 6 different gas blends for the country. Since 2000 there is over 90 different blends for the country. And people wonder why we were paying so gas a coulpe of summers ago. All those blends hurt supply. I say why don't they just pick the cleanest blend and use that as the new standard.
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
