acceleration problem
Old Aug 29, 2002 | 06:58 AM
96SE5Spd's Avatar
I have replaced my knock sensor my spark plugs and my fuel filter, my ecu is throwing the 0505 code but my car still has that wierd feeling durring acceleration assosiated with the knock sensor, any thoughts on what else could be going on with my car.
Old Aug 29, 2002 | 07:52 AM
maximachad's Avatar
Lifetime Maxer
Oxygen sensors?
Have you replaced your O2 sensors? Just a thought...if you're talking funny acceleration when you're NOT wide open throttle, then it could be tired O2 sensors...
-Chad
Old Aug 29, 2002 | 10:27 AM
njmaxseltd's Avatar
When's the last time your cleaned or replaced your air filter?
Old Aug 29, 2002 | 10:33 AM
Chino's Avatar
How badly can this affect peformance/acceleration? I've cleaned out my HKS sponge filter twice but it just doesn't seem to be clean enough.
Old Aug 29, 2002 | 03:32 PM
JeffesonM's Avatar
living out of a maxima...
My old Maxima (92) ran like poo until I changed the air filter, fuel filter and plugs. Then things were peachy.
Old Aug 29, 2002 | 07:05 PM
keener's Avatar
Are you running 90+ octane gas?
Old Sep 3, 2002 | 06:43 AM
96SE5Spd's Avatar
I do need to clean my filter its been a year now and probably needs to be cleaned, I run 93 octain, and I probably need to replace my O2s but I thought that you should leave them alone unless they throw a code.
Old Sep 3, 2002 | 12:47 PM
Carlos A's Avatar
I have the same problem
I have the same problem, eve though I have installed new spark plugs, fuel filter, PCV valve, O2 Sensors. I have not yet replaced the knock sensor.
Just by curiosity, have you reset your ECU?
I have read that if youchange the knock sensor and do not reset the ECU, the car will have the same behaviour.
The symptoms are:
- Sluggishness,
- Weird accelerations (almost a random rocking)
- Feel (some times) like there is wind against you when accelerating
- Motor roars like it should be pulling faster but the accelration does not match the motor sound.
- Could be mistaken with a clutch slipping.
Old Sep 3, 2002 | 01:20 PM
darksands's Avatar
I have a problem with my acceleration too... Its slower than an M3's. Okay... Lame but oh well.
Old Sep 4, 2002 | 07:23 AM
96SE5Spd's Avatar
Re: I have the same problem
The symptoms are:
- Sluggishness,
I reset my ecu but as long as I'm WOT the car is fine, in fact I had it at 140 mph this weekend, so I'm pretty sure my clutch isn't slipping, I'm begining to thing it is my O2s but they can wait the car does fine otherwise.
Old Sep 4, 2002 | 10:44 AM
95Max's Avatar
Blocked exhaust? I had weird acceleration when my flex section had colapsed. Now with the new flex the problem is gone.
Old Sep 5, 2002 | 08:38 AM
maximachad's Avatar
Lifetime Maxer
How can you tell if your flex section has collapsed?
-Chad
Old Sep 5, 2002 | 10:54 AM
sinewave's Avatar
Also check to see if your brakes are dragging. Put the car up on jack stands and turn the wheels by hand.
Old Sep 6, 2002 | 04:57 AM
95Max's Avatar
The only way to tell if the flex has collapsed is to look inside. Disconnect the y-pipe from the cat and look in.
msellas
Sep 23, 2015 09:16 PM
jchronis2552
Sep 21, 2015 05:52 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
