Nokya headlight bulb melted harness
Old Aug 30, 2002 | 09:49 PM
acidflea's Avatar
I have a 96 maxima SE and a while back i had one of my headlight bulb harnesses melt. I have the Nokya 9004 bulbs. I replaced the harness with a new one from nissan but put my stock bulbs back in. I was wondering if this is a common problem with these bulbs. If i switched to PIAA bulbs would I still experience the same problem? Is there a bid difference between the PIAA bulbs and the APC bulbs? The APC bulbs are about $20 for the set and the PIAA are $70 for the set around here. Any help would be appreciated. Thanks in advance.
Old Aug 30, 2002 | 09:58 PM
SamMan23's Avatar
Dealer told me that they've been having lots of melted harness lately from aftermarket bulbs. You just have to make sure the bulbs run the same wattage.
Old Aug 30, 2002 | 11:38 PM
Gotrice4's Avatar
Re: Nokya headlight bulb melted harness
I have Nokya Artic purple bulbs, they are overwatts at 80/100. I run an upgrade lighting harness because my stock harnesses were showing signs of melting/failing. If you do run overwatts, upgraded harness(or some people believe all you need is to change the gauge of the grounds)are recommended because of the increase in current draw increases the temperature of the harnesses. So, either get the PIAA's in the stock 45/65 wattages(which you won't be happy with if you liked the Nokya color) or another HID knock-off bulb with the stock 45/65 wattage.
Old Aug 30, 2002 | 11:50 PM
zntema's Avatar
i had the nokya bulbs on for a while and it melted my harness. i upgrade the harness and my relay start buzzing
i was wondering which relay it is the lamp relay or the headlight relay i should replace cause the price on the one of them was almost 200 cdn and the other is 30 bucks...
thanks!
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
