Camber Adjustments
Old Sep 1, 2002 | 11:33 AM
DMaximus's Avatar
Camber Adjustments
Need some help from you since this forum seems to possess excellent detailed knowledge on the Max's alignment stats. I recently installed the KYB adjustables w/Eibach springs. Since that time I had an alignment.
Here are the findings:
Caster: left-front is 2.3 and right-front is 2.8.
Camber: left-front is -1.4 and right-front is -1.3.
Toe: left-front 1/32" and right-front is 1/16", the total was 1/16".
My rear Camber: left-rear -1.3 and right-rear -1.2.
What are your recommendations as for the adjustments that need to be made?
Since the rear camber can't be adjusted is there like some shims that could be used to balance it?
Old Sep 1, 2002 | 12:42 PM
njmaxseltd's Avatar
Don't touch it!
Dont do a thing! It's perfect.
Your a little bit into the negative camber area, but thats only going to make you handle tighter. What I like about your readings is there extremely close to each other. -1.4 & -1.3 Thats very good!
As long as your toe is set correctly, which it is at 1/16 total your tires will wear just fine. Don't be alarmed that your out of spec on the negative camber. Rotate your tires every 4 - 6 months, depending on your mileage and enjoy the extra bite you'll get on curves with your settings.
Old Sep 1, 2002 | 12:45 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Don't touch it!
But, that negative camber that gives you bite in turns can hurt you at the strip. The negative camber makes your static contact patch smaller. This means less traction off the line.
Don't worry about it, just remember that it's a triple edged sword.
Old Sep 1, 2002 | 03:28 PM
BEJAY1's Avatar
Conecarver
Agreed - leave it alone. All left & right numbers are perfectly close. Now if you're planning something special...
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
