max with 112k, is PENNZOIL oil for cars over 100k good or bad oil for my max??
Old Sep 2, 2002 | 10:05 PM
95seMax's Avatar
pennzoil makes an oil for cars over 100k , i have 112k on my max and was wondering if this oil is good to use for my car, or should i just use syntetic, even though i am broke
has anyone used this in their max??
Old Sep 2, 2002 | 10:10 PM
Jeff92se's Avatar
I'm needing a caw
If it's in good running order, I see no real need to change. Get your oil analyzed by Blackstone labs(do a search) and see how your oil is performing. If you are really that curious, get a mechanic to do a compression and leakdown test also.
No one here can really comment on what oil to really use because no one knows the condition of your engine of your engine. It could be almost new inside or all beat up. Depends on how you treat it and how you serviced it.
Old Sep 2, 2002 | 10:21 PM
rmb's Avatar
rmb
Re: max with 112k, is PENNZOIL oil for cars over 100k good or bad oil for my max??
If you're broke, as we all once were, just use a good name brand regular dino oil like Castrol GTX 5w30 and change it every 3-5k. Use an OEM filter. Sure synthetic would be better, but quite frankly probably not that much better if you change it frequently and don't beat the hell out of your engine.
Save the Mobil 1 for when you buy a new Max(or Porsche).
-RMB
Old Sep 3, 2002 | 12:07 AM
munji's Avatar
After ripping apart my friend's 350 in his '71 Camaro, and seeing the effects of Pennzoil, I swore to never use it but........I use Quaker State and all is well...............
Old Sep 3, 2002 | 02:40 AM
$tillen$ux's Avatar
Pennzoil..never again. I used synthetic pennzoil once, stepped on the acclerator and smoke came out (oil burned). Switched back to mobil 1 and never happened again. Pennzoil sucks. wouldnt reccommend it (at least synthetic)
Old Sep 3, 2002 | 07:17 AM
iwannabmw's Avatar
Aren't Penzoil and Quaker State under the same corporate umbrella now??
According to Bill's spreadsheet, if you're going to use dino oil, it looks like the Castrol GTX would be your best bet.
Old Sep 3, 2002 | 08:52 AM
92vemaxse's Avatar
Pennzoil has wax in it and will build up inside your engine, so don't use that. I say use Castrol GTX, IMO, it's the best non-synthetic oil.
Old Sep 3, 2002 | 09:01 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
There's nothing wrong with Pennzoil. The next spreadsheet update includes a member here who has used it exclusively for 100k miles with 3k interval changes. He just recently switched to Amsoil, but his lab analysis came back quite beautiful for an engine with over 100k on it. But he didn't beat the crap out of it also.
I think such contentions against Pennzoil are unfounded. That being said, I would use Castrol GTX.
Pennzoil's full synthetic looks to be a BAD choice based on baseline analysis results. In many ways it looks WORSE than good dino oils such as Castrol GTX, etc.
If you want to learn more, click on the link in my sig.
Old Sep 3, 2002 | 08:53 PM
95seMax's Avatar
i think i should swith then maybe try castrol , i've been using regular pennzoil oil 10 -30 in my car b/c some mechanic told me its better, but i think i will follow fellow max owners advice instaed thanks all
Old Sep 3, 2002 | 11:36 PM
chris j vurnis's Avatar
I wonder what they do to make it "formulated for higher mileage".
Maybe its all just the same stuff with a different label on the container
Maybe they just add some weight or viscosity to make it leak less past the piston rings. Probably no different than just buying the "regular" oil with a heavier weight.
Old Sep 4, 2002 | 03:54 AM
djmayhem's Avatar
about oil....
what does everyone think about the amsoil synthetics???
Old Sep 4, 2002 | 04:33 AM
97GLE's Avatar
Castrol GTX 5W-30.... You can get it at Wal-Mart in a 5 quart jug for ~$6
Old Sep 4, 2002 | 05:39 AM
bill99gxe's Avatar
Re: about oil....
http://forums.maxima.org/showthread....hreadid=100060
Old Sep 4, 2002 | 05:44 AM
bill99gxe's Avatar
If you want an intelligent and lab proven answer, click here:
The spreadsheet has Baseline oil analyses of Castrol GTX and Castrol GTX "High Mileage". Suffice to say it is a marketing gimmick to get you to spend $2.20/quart on oil instead of $1.80/quart.
Old Sep 4, 2002 | 07:05 AM
iwannabmw's Avatar
Re: about oil....
They're great
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
