Changing knock sensor?
Old Sep 3, 2002 | 06:10 PM
jeavel
i have a 96 max auto and theres a green plug in the way so i cant fit my hands down there to get to the knock sensor what tools do i need ?
Old Sep 3, 2002 | 06:31 PM
PhatBastard's Avatar
Re: Changing knock sensor?
http://www.skippynet.com/maxima/knocksensor.htm
Old Sep 3, 2002 | 11:14 PM
BriGuyMax's Avatar
smaller hands
Old Sep 4, 2002 | 07:27 AM
Rickalodeon's Avatar
Re: Re: Changing knock sensor?
Here's an addendum tip...The 1/4 drive (w/flex socket) works great to remove the bolt after it's been loosened. But it doesn't always work to break it loose (requires more torque than the small diameter extension can handle). For that, I had to revert to a 3/8 drive...Once, the bolt turned freely, I used the 1/4 drive to take it the rest of the way.
Old Sep 4, 2002 | 12:00 PM
Stillen_I30's Avatar
i bought all the angled and smaller drive sets and none worked. i reverted back to the original drive i've always had, and instead, used a very large screw driver i found in the basement, and used that as a lever propped against some rigid metal bracket down there. the bolt snapped loose very easily.
bbsitum
Sep 6, 2019 07:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
