Should Oxygen sensors be replaced in pairs??
Old Sep 4, 2002 | 05:33 PM
maximachad's Avatar
Lifetime Maxer
I had to replace one of my front oxygen sensors a couple of months ago, and I've just noticed that my car is getting sluggish in the lower RPMs. Could replacing just one oxygen sensor cause this? I know the ECU uses the signals from the sensors to control the fuel injection/fuel mixture. I have no codes in my ECU. Any thoughts?
-Chad
Old Sep 4, 2002 | 05:46 PM
SuDZ's Avatar
Re: Should Oxygen sensors be replaced in pairs??
-Chad
Have you ever cleaned your throttle body or your IACV? Has you car had a tuneup? How many miles on it? These can help to figure out if it may be something else as well.
SuDZ
Old Sep 4, 2002 | 06:41 PM
Kevin Wong's Avatar
Well, I noticed on my dyno that I'm short about 20 HP and my car does feel more sluggish. So I decided to change my 56K mile old plugs, fuel filter, and PCV. Still not as good as before, so I had my local indy Nissan mechanic run the CONSULT scan tool. He said after driving the car for 2 miles, the O2 sensor light came on and off 3 times. It seems like it might be shorting out or something. It's not out enough for the CEL to come on, but I have noticed that I'm a few miles per gallon. He suggested changing all 3 for my 97. He told me to call around a try to find a good deal at some dealerships (buying 3 can oddly cost as less as buying 2). Finally he told me that the O2 sensors on the 95+ Maxima and 92+ 300ZX's seem to have problems after 5-8 years of use.
Old Sep 4, 2002 | 08:52 PM
Ramius83
Would you happen to know the best/cheapest place to buy these 02 sensors at? I have noticed HORRIBLE fuel mileage and also the 02 sensor CEL came on about 7k miles ago. Thanks Kevin.
Old Sep 4, 2002 | 09:00 PM
Sexima's Avatar
I am calculating my full tank right now and I think I'm lasting 270 on a full tank...
I heard of people with new o2 sensors lasting 400+...
and my CEL didn't even come on..
I think I'm just going to change my whole thing...
where is a cheap place to get O2 sensors?
Old Sep 5, 2002 | 08:40 AM
maximachad's Avatar
Lifetime Maxer
The best place for O2 sensors is Autozone. Go to a local Autozone store, or www.autozone.com. They have our stock Bosch O2 sensors for $59.99!!!
-Chad
Old Sep 5, 2002 | 08:43 AM
maximachad's Avatar
Lifetime Maxer
Re: Re: Should Oxygen sensors be replaced in pairs??
SuDZ
Yes, my car has had all maintanance done, including plugs, new alternator (recall), new fuel filter, all flushes, new air filter 1 new O2 sensor. The car just isn't pulling like it used to! 97K on the odo. Please help!!
-Chad
Old Sep 5, 2002 | 09:25 AM
maximised's Avatar
Re: Re: Re: Should Oxygen sensors be replaced in pairs??
-Chad
About the Alternator recall, I am not the original owner of the car, it has 59,280 miles on it, can I still take my car to the dealership and have the alternator replaced free of charge?
Does my car still have some kind of warranty on it that I (second owner) can take advantage of?
Old Sep 5, 2002 | 11:43 AM
Sexima's Avatar
Re: Re: Re: Re: Should Oxygen sensors be replaced in pairs??
yea you can go take it.
Mine is used also but they didn't ask me any questions about that.
We made an appointment, it was done in about 3-4 hours.
Old Sep 5, 2002 | 12:08 PM
MAXSRB's Avatar
So many of my problems at once. I too have a sluggish max in the lower rpms. There is a huge noticeable difference in the way the car acts sometimes. I changed my o2 and knock sensors and it still does not feel no where near as powerful as before. What can we do?
Old Sep 5, 2002 | 03:41 PM
maximachad's Avatar
Lifetime Maxer
Anyone!??
Old Sep 6, 2002 | 10:06 AM
maximachad's Avatar
Lifetime Maxer
-Chad
I KNEW IT!!! Last night, the service engine soon light came on...the other O2 sensor is bad! Dropped it off at Nissan this morning, because this sensor looks harder to get to. Hopefully my car is back to normal tonight...
-Chad
Old Sep 6, 2002 | 12:51 PM
WizzaMax's Avatar
-Chad
th weebsite lists no part available in the search...I am gonna try the local store then the dealer.
Old Sep 6, 2002 | 12:54 PM
SuDZ's Avatar
Make sure when you search for 02 that your using a zero and not the lotter O.
SuDZ
mrc00l88
Jan 25, 2024 01:14 PM
03VQMAX
Sep 25, 2015 04:19 PM
Maxboy23
Aug 21, 2015 11:02 AM
jchronis2552
Aug 13, 2015 07:48 AM
MikesChevelle
Aug 6, 2015 11:36 AM
