Ohhhh man got the check engine light and it doesnt look pretty
I got a 04 07 engine code. I have a problem with my crank shaft position sensor. At the end of the code it says "reference" what is that refering too?? How can I fix it? Can I fix it myself?? I have a 95 5 speed if anyone can help that would be fantastic.
There are 2 crank shaft sensors. One is called reference and the other is called..... well a crank shaft sensor.
I think, don't take me 100% on this one..... that the reference one is located near the crank pully and the reference one is located near the flywheel.
It may be the other way around. Bottom line is there are 2 crank sensors, just make sure you replace the correct one.
Originally posted by americanidol
well im a fantastic guy, so im going to tell you to chcky the FAQs for this generation. have a great day
Go BENGALS
Go BENGALS
You've learned the maxima.org ropes quickly, I see.
Go BENGALS
Go BENGALS
Originally posted by Ramses718
AHAHAHAHAHAHAAHAHA your a pretty corny guy. I did a search but couldnt really find a decent description of where and how to get to the sensor.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
