Finished interior lighting, check it out.
Last year, I did the reverse indiglo gauges & intelliglow needles, window switches and security led. Now I finally finished the rest of my interior lighting. I did the hazard & rear defrost buttons, climate control, ignition key ring, shifter light, and matched it up with a Kenwood MPV-619 MP3/CD radio. Let me know what you think.
-Ben
-Ben
![](http://images.cardomain.com/installs/131000-131999/131277_138_full.jpg)
![](http://images.cardomain.com/installs/131000-131999/131277_139_full.jpg)
Re: Finished interior lighting, check it out.
-Ben
-Ben
Re: Re: Finished interior lighting, check it out.
Originally posted by sidewinder740
looks pimp...nice how you got everything to match up
Originally posted by Blkmax95c
looks really good.... how long did it take to do all that? what was the hardest thing to change? i wanted to do that to my max. but good job.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Re: Re: Re: Finished interior lighting, check it out.
Originally posted by maximised
What about when the climate control is turned on? Did you manage to get that to change color? That is the only thing holding me back from doing the same thing, that green has got to go!
Let's say the gauges were about 2 hours, window switches 2 hours, climate control an hour, defrost & hazard an hour, ignition half hour, shifter light 5 minutes, radio install an hour. I say the hardest one would be the climate control, for some reason I had trouble getting the leds to stay secured to the board.
Originally posted by Toolrocks
What LEDs did you use for the climate control. THey look nice and bright. Do you know the specs? Can you tell me where to get em - I've tried a few but they are never bright enough. Looks great though. Your car always does.
BenB looks sweet as usual!! I was just about to order mine and i did a search and found this post. nice!
one question. did you use 5mm LEDs or 3mm? I have 5mm LEDs in my window switches and was thinking of getting the same ones for the dash so they will all match up. i'm not sure if the 5mm will fit in the dash though.
I used the 5mm ones all around. I don't know if it'll work in the manual ac control, but they do work in the auto climate control.
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
so you basically used one LED for each button?
thanks. judging by the pictures it looks like we have the same ac control.
then again you have a 98 GLE or GXE and I have a 96 SE.
There is 4 locations for bulbs/leds behind the A/C control and one led each to illuminate the hazard, defroster, dimmer, and cruise control buttons. 5mm will work in the A/C but you have to file them down a little bit. The main thing, if you're doing the A/C, is that you get LEDs with the highest mcd rating you can find. That relates to the brightness of the led. Chekc out this link if you haven't all ready. http://www.z3d.com/maxima/blueclimate.html
just ONE question...are all the bulbs EXACTLY the same? like if i wanted to chang all bulbs from the doors to the climate to clock, are they all the same size? And why couldn't u change the clock bulb?
You may as well just go ahead and get the SC - you know it's only a matter of time.
Yea, right now I'm debating on either getting a loan for one or the other, because of parts and labor to do the conversion, I think I might be leaning more for the SC, but yea, its only a matter of time.
Wait out for a TC, you'll be so much happier with it. Why do you think VW's, the 300z, and other cars come STOCK with turbos, because they yield better results. Get the SC now, and get another blower next year. And the year after, and so on...
Well, the turbo kit that's out there right now is a little too expensive for me, $4500. Either way, I just want to have some kind of boost ither than NAWWS.
Then don't get the intercooler, run it at a lower psi, and you'll get just as good results. Then add the intercooler later, and enjoy phenominal power from your family sedan
King_Ten_Ahead
09-30-2015 04:27 PM
MaximaDrvr
08-19-2015 08:20 PM
