Should I use 110 octane fuel?
Old Sep 9, 2002 | 02:18 AM
CASS98SE's Avatar
At my local drag strip you can get 110 octane race fuel.. Would this benefit my car in any way, or do you think it may actually hurt the performance. I just have simple bolt on mods
Old Sep 9, 2002 | 02:24 AM
Nismo's Avatar
you wont get anything out of it.
Old Sep 9, 2002 | 03:01 AM
TurDz's Avatar
It will hurt performance and can possibly burn out O2 Sensors or your Cat.
High ocatane gas is used for very high compression cars running lots of power. Maximas are better off using octane in the 90s.
Old Sep 9, 2002 | 10:50 AM
95emeraldgxe's Avatar
dont waste your money - 3-4 dollars a gallon
Old Sep 9, 2002 | 10:59 AM
universe517's Avatar
Re: Should I use 110 octane fuel?
There's no point unless you are running high boost. You don't need anything higher than 91-93. The higher the octane, the higher the rate of combustion..... higher octane prevents knocking in high compression engines.
Old Sep 9, 2002 | 11:03 AM
sinewave's Avatar
Re: Re: Should I use 110 octane fuel?
Actually, the higher the octane rating, the LOWER the rate of combustion.
Old Sep 9, 2002 | 11:35 AM
Corion's Avatar
I thought high octane gas cleaned out your fuel system?
Old Sep 9, 2002 | 12:28 PM
makattack's Avatar
you can't use it
110 octane is leaded. Your car runs on un-leaded, it will clog and possibly seize your engine.
Old Sep 9, 2002 | 12:48 PM
rmb's Avatar
rmb
Re: you can't use it
If it is leaded it won't seize your engine but it will destroy your cats....
-RMB
Old Sep 9, 2002 | 01:24 PM
maximised's Avatar
Re: Re: you can't use it
-RMB
Yeah lead acutally helps with the friction b/t the piston and cylinder wall, it was good until they found out it was bad for the ozone
Old Sep 9, 2002 | 01:25 PM
sinewave's Avatar
Nope. The higher the compression or the more ignition advance, the more you need a slower burning fuel to prevent pre-detonation. But if 91 octane solves your pre-detonation problems, increasing octane has absolutely no additional benefits.
It's like running shoes. If you wear a size 10 but buy size 8, your performance suffers. You put on 10's and you can run great, but wearing 12's doesn't make you faster.
Old Sep 9, 2002 | 03:34 PM
Re: Re: Re: Should I use 110 octane fuel?
I stand corrected... But I have the concept straight, right? I'd like to know if I don't know what I'm talking about
Old Sep 9, 2002 | 05:30 PM
iregula's Avatar
just dont use it
Old Sep 9, 2002 | 05:50 PM
InfamousOrange's Avatar
higher ocatne= better for engine
110 octane is alot better for ur engine, ie u will get more power. especially if u have a super on there. 91 is like water compared to 110. but i dont recommend 110 for daily driving, its way too expensive
Old Sep 9, 2002 | 06:02 PM
RodolfoGraziani
Ethyl Alcohol!!!!
Yup, use the good stuff BP/Amoco is using in their super expensive gas.
Buy Ethyl Alcohol and pour it down...that should give you the cheapest solution of making 150+ AKI.
It will be bad for engine if you run regular at this ridiculous level, but when used with caution, it can achieve supermotor effort (like beating Cobras).
Luck.
Old Sep 9, 2002 | 06:14 PM
densetsu's Avatar
Re: higher ocatne= better for engine
somebody didn't read the thread
Old Sep 9, 2002 | 06:57 PM
BBaker025's Avatar
The usual .org answer, try it and find out
Old Sep 9, 2002 | 07:29 PM
maximised's Avatar
Re: Ethyl Alcohol!!!!
Luck.
Ammoco gas
Exxon gas
We dynoed bikes that used both gases exclusively. Exxon make more HP, burns better.
Old Sep 9, 2002 | 08:17 PM
krbga's Avatar
$3.99x18=$71.82 (I think I feel it)...
or $12.99 fuel filter + $3.99 throttle plate cleaner = restored POWER!
enjoy the ride.
Old Sep 25, 2002 | 12:33 AM
thnikkamax's Avatar
Ludicrous Speed
Re: Re: Ethyl Alcohol!!!!
Originally posted by maximised
Ammoco gas
Exxon gas
What's your take on Chevron w/Techron vs. Exxon?
Old Sep 25, 2002 | 05:24 AM
deezo's Avatar
Re: Re: Re: Ethyl Alcohol!!!!
They're good also.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
JoshG
51
Sep 21, 2015 10:41 PM
