Humming, grinding and loose in the front
Old Sep 9, 2002 | 02:09 PM
sethhirschel's Avatar
Ok, my '96 SE has 152k on it. all original, and I'm proud of the car.
Now the front end is falling apart. it's loose, and loud and dringing (like it needs bearings) the wheel vibrates above 60 and goes away at 80. my front tires are getting worn to all hell (fish scales and all).
i have 17" momo's, eibachs, tokicos, and stillen brembo rotors.
i just ordered t 2new factory bearings, rotors and pads all 4 corners and new kyb agx (gonna leave the eibachs in there). i'll have all this done and an alignment./balance and i think i should be back to tight ride and less noise!
i ho1pe this will fix my problems. should i be doing other work while i'm in there? maybe bushings? any sugestions? anyone been in this spot?
seth
Old Sep 10, 2002 | 02:33 PM
Mr Cranman's Avatar
What you got should fix it with no problems. It sounds like it is the wheel bearing is actually failing...and most likely an alignment issue. But, other than that you should be set You don't really need to replace anything else while your under there.
-John
Old Sep 10, 2002 | 02:45 PM
sinewave's Avatar
I would suggest that you check the ball joints and lower control arm bushings. With 150K miles, you are definately at the far end of their life expectancy.
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
