What is the KLUNK when I turn?
Old Sep 13, 2002 | 12:39 PM
Skoodaddy's Avatar
I was slightly run off the road at 65 mph and it busted my CV boot, had it replaced the next day, 1 week later, I got the new rims and the other one busted, had it fixed the next day, since the last one there is a klunk when i turn. I took it to the shop, my mechanic said the CV joints were both fine and no slippage marks present, he asked about the FSTB, and while I was explaining it I noticed it looked a little "higher" on one side, so I took it off, now it only Klunks when I turn left, but the car sems to handle better with it off, but what is this klunk stuff? any ideas?
Old Sep 13, 2002 | 01:51 PM
skeelo34's Avatar
Re: What is the KLUNK when I turn?
klunk!
Old Sep 13, 2002 | 02:05 PM
Skoodaddy's Avatar
Re: Re: What is the KLUNK when I turn?
Originally posted by skeelo34
klunk!
Yeah, Klunk, not a pop or a ping, but a pretty heavy sounding Klunk, My first car was an '82 Honda Civic (I've learned since then OK) and the CV joints were way out and when I turned sharp it was a clakety clackety sound, but this sounds ummm....thicker? I dunno, give me some ideas, it's not affecting any performance (so far) but I'm about to road trip about 2,000 miles and I don't need no problems
Old Sep 13, 2002 | 02:07 PM
skeelo34's Avatar
Re: Re: Re: What is the KLUNK when I turn?
Whoa, I just remembered, i had that with my old 87 z24, and on my ex gfs jetta. It only happened when turing sharply at slow speeds. Needless to see, the jetta tranny blew on one of those turns. I don't know what it was, but it wasnt good. My car makes a popping sound whenever I turn from far left to far right while stopped. I dunno what it is. If anyone knows about that one, let me know.
Old Sep 13, 2002 | 02:41 PM
cmac95gxe's Avatar
Maximaniac
axle maybe?
Old Sep 13, 2002 | 03:18 PM
pmg's Avatar
pmg
could be the axle. I had 2 go on a Ford Probe.
Old Sep 13, 2002 | 04:45 PM
JeffesonM's Avatar
living out of a maxima...
Re: Re: Re: Re: What is the KLUNK when I turn?
I too have this problem and some have suggested it may be the strut bearing. I have not looked into this yet.
Old Sep 13, 2002 | 10:52 PM
JPMax's Avatar
What's next!?..
Could be the strut bearing. If it's damaged, it won't turn easily and just build up tension in the spring until POP.. it moves all at once.
JP
Old Sep 14, 2002 | 06:22 AM
njmaxseltd's Avatar
You were run off the road "slightly"
Popping noises are spring related. Causes are strut bearings or worn spring isolators, incorrect spring installation. Lets assume your spring/struts have not been disassembled. Lets rule the strut assy. out here.
When you went off roading, did you jump a curb or something like that? If so, I'd be looking at your lower control arm bushings. They probably took quite an impact. Expecially if your busted a CV joint.
Old Sep 16, 2002 | 06:18 AM
Skoodaddy's Avatar
Where I was run off th road, was on a soft gravel shoulder, but bumpy enough to bust the cv boot, the springs shocks/struts were installed Feb. and not probs till this happened
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
salty318
Sep 29, 2015 01:21 PM
