installing HIDs from acura...HELP NEEDED
Old Sep 15, 2002 | 08:13 PM
way2fast95's Avatar
Does anyone know where I can get instructions for installing an HID kit? The ones i have are H4 from an acura and I honestly have no idea how to do it. Need any advice on doing this you all can provide, even instructions to a standard 9004 HID kit would help.
Thanks Everyone,
Anthony
Old Sep 15, 2002 | 09:10 PM
97GLES's Avatar
Re: installing HIDs from acura...HELP NEEDED
Thanks Everyone,
Anthony
you will need some glue.
Old Sep 15, 2002 | 09:14 PM
ny96max's Avatar
Re: Re: installing HIDs from acura...HELP NEEDED
lmao!
oh yeah and lots of time
Ant
Old Sep 15, 2002 | 09:20 PM
96shogunmax's Avatar
Re: Re: Re: installing HIDs from acura...HELP NEEDED
Originally posted by ny96max
lmao!
Ant
b/c their H4's ?????
Old Sep 15, 2002 | 09:21 PM
way2fast95's Avatar
FYI, my biggest problem is lack of wiring diagram. thanks.
Old Sep 15, 2002 | 09:24 PM
97GLES's Avatar
your biggest problem will be installing the light bulb perfect in the housing uless you buy a set of 9004 hid bulbs.
Old Sep 15, 2002 | 09:27 PM
Hope you got a h$ll of a deal on this
Old Sep 15, 2002 | 09:41 PM
97GLES's Avatar
Old Sep 15, 2002 | 09:47 PM
Old Sep 15, 2002 | 09:56 PM
SLC I30t's Avatar
So since I have H4's in my 97 I30, I could use a HID kit off of an Acura TL? What about an Audi?
Old Sep 15, 2002 | 10:24 PM
way2fast95's Avatar
Yeah i did get a very good deal It was worth it.
Yes you can use HIDs from an acura if you also have H4, so can anyone with 9004, you just have to mod it alittle.
Old Sep 15, 2002 | 10:30 PM
Old Sep 16, 2002 | 12:41 PM
way2fast95's Avatar
Anybody?
Old Sep 16, 2002 | 12:46 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Anybody?
so you need a wiring diagram for the acura HID harness or for your 95?
Old Sep 16, 2002 | 01:06 PM
way2fast95's Avatar
If at all possible.
Old Sep 16, 2002 | 02:17 PM
Bags's Avatar
If at all possible.
Ok.. lol.. I am a little confused.
Do you need
A) the 95 maxima headlight harness wiring diagram?
or
B) the acura HID wiring harness diagram?
or do you need both?
I have a FSM for a 97... although the wires might be different it might give you some help for the maxima.
I have nothing for an acura
Old Sep 16, 2002 | 03:26 PM
way2fast95's Avatar
Since the info I need is HID specific (ballasts, ignitors, etc.) I do not believe this would really help, but thanks anyway.
Old Sep 17, 2002 | 05:08 AM
Albertt's Avatar
SLC I30t >>
Besides firearms, I'm also into automotive lighting.
I would advise against going with HIDs if I were you. You'll lose your highbeams and the light, though brighter, will not have as precise a beam pattern compared with your H4s.
Also, you will not be able to use the HIDs straight from an Acura or Audi. They use the D2R and D2S bulbs in their "natural" form. The conversion kits modify those two bulbs (which are essentially the same except for the gas capsule locations and mounting flange) by adding flanges that fit the various bulbs like 9003, 9004, 9006, etc.
If you want to improve your headlamps, the ONLY thing you should do (at this point in time) is to swap out the stock bulbs for Philips VisionPlus which are the best out there.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
