foglight removal tips????
I assume yours is probably like mine. I have a 95 and to remove the lens do the following; on the front of the lens towards the center of the car will be a piece of the lens that is slightly different from the rest. Push in on the top of this piece and the bottom should pop out. Remove this piece and you should have access to one screw. Remove the screw and then pull the light housing out. When you reinstall it, you'll see two little prongs that will need to line up with inserts. Hope this helps, I don't really know how to explain this.
my03maxima
07-28-2024 07:40 AM
RealityCheck
10-02-2015 06:34 PM
