ECU Codes
Old Sep 18, 2002 | 08:54 AM
adam714's Avatar
ECU Codes
I'm having a problem reading these codes. I put it into diagnostic mode. It looked like 9 long pulses but then the short pulses would go in a 01 01 sequence but over and over again without stopping until i turned the screw back clockwise. Now when i start the car, the check engine light does not come on.
What do i do now?
Old Sep 18, 2002 | 09:04 AM
redmaxpa007's Avatar
i SeE what you did therE
well you cleared the code..
http://vbxmaxima.8m.com/ecudecoder.html
Old Sep 18, 2002 | 09:17 AM
adam714's Avatar
Well, i didn't follow the procedure for clearing the codes but if i did clear inadvertently, how do i determine the problem?Theoretically, if there is still a problem, the check engine light should re-appear, eventually, correct?
Old Sep 18, 2002 | 09:18 AM
you sir are correct..
Old Sep 18, 2002 | 09:29 AM
adam714's Avatar
COOL!
Old Sep 18, 2002 | 09:33 AM
COOL!
actually getting the code to reappear means you have to get something fixed.. just hope the ECU stopped talking to something for a second and gave you the code.. my ECU and tranny did that once..
i cleared it and no more code.. car is working fine
Old Sep 18, 2002 | 05:58 PM
adam714's Avatar
I'm not sure what you mean by that but here's the thing.
I initially thought the code i got was 0902 but when i entered it at
this site it says undefined. however i did find an 0902 here
Now i'm completely confused.
Old Sep 19, 2002 | 03:35 PM
adam714's Avatar
OK, even though the check engine light cleared, there seems to be a problem. Now when i start, it does right out. i have to rev it in order for it to not shut off. once it's going . no problem
any ideas?
Old Sep 22, 2002 | 11:47 AM
adam714's Avatar
getting worse
Max won't start unless i give it gas while cranking. Don't know what to do. i don't have a mechanic i trust and don't want to take it to dealer.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
