Replacing Factory Bose Speakers
Old Dec 19, 2000 | 11:51 AM
DOUBLEJOON's Avatar
95 SE
Can you replace the Factory Bose speakers with an aftermarket brand using the same factory amplifiers?
If so what brand and model?
Or do I specificly have to get the exact factory speakers as replacements?
Old Dec 19, 2000 | 01:12 PM
DavidM's Avatar
speakers
can't use any other speakers with the Bose amps, there was an article on that here a few weeks ago, the amps operate almost like a class D amp which pulls little amperage but puts out a lot of power, if you were to use an aftermarket speaker you'd probably end up blowing it using the bose amps as most speakers (except subs) are capable of handling a low ohm rating.
Old Dec 19, 2000 | 01:26 PM
Micah95GLE's Avatar
The speaker determines the ohm load, not the amp. Theoretically, if you wire a typical aftermarket speaker to a Bose amp, the amp will make about 1/4 the power that it did with the Bose speaker.
Old Dec 19, 2000 | 01:43 PM
Bernie Lomax's Avatar
Also, the BOSE amps are part of the speaker cluster, so it's not really possible. They are mounted to one another.
MikesChevelle
Nov 23, 2024 11:17 AM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
vingodine
45
May 21, 2016 12:46 PM
melteye
May 16, 2016 12:02 AM
MikesChevelle
Aug 9, 2015 11:50 AM
